LS430 Big Brake Swap
+34
Tehone
Psychoideas
mvallee
Vic-S2V8
87wolfsburg
laptop_geek
gamman
Walkerhiboost
Bluemach1
Bluemongoose
adam7e
modenas
subterfuge
kelleysj
Ender751
Vorsche944
jimbo93
m73m95
968gene
Tetzuoe
tooms351
coctostan
msmoorenburg
Johnny Johnny
38 posters
Page 1 of 10
Page 1 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
First off, I don't own a patent and could care less if you made 100 sets. I'm not a big company that pretends I have a patent and kicks you off a public forum because I actually have no legal recourse.
I came up with the Lexus Caliper idea so I didn't have to spend 1200 hard earned dollars to line the Pockets of some snooty bastard behind a keyboeard.....I am designing more things for the 944 V8 swap and will only post details on this forum from now on.
That being said, anything I design and offer for sale, I will first post diagrams for anyone that wants to do it himself or herself for that matter. The 86 turbo is the unknown and it is being worked on.....POPP
For Early cars you have to machine your hubs like this
For late cars you need billet centering rings like these
And Adapter brackets have to be precision machined accordingly
Re: LS430 Big Brake Swap
Glad to see you back! This has all been such BS. Thought I'd supplement the above diagrams with RL pics of the setup.
Hub that has been machined:
Lip inside R1 Boxster S rotors:
Rotor mounted to hub:
Johnny Johnny- Posts : 164
Thanks... You RULE!!!!!!! I hope Doug got a lot of money for the other forum, because who ever bought rights to it now owns a GHOST TOWN.....
Dawgz83948- Posts : 603
here is a quick brake down on what you will need (please correct if i'm wrong)
1. Boxster S rotors 00-04
2. Lexus LS430 Brake Calipers 00-04
4 ea. 4" length 9/16 - 18 (TPI) bolts
4 ea. 9/16 flat washers
4 ea. 9/16 lock washers
4 ea. M12 x 1.5 x 45mm length bolts
msmoorenburg- Posts : 75
"""""LS-430""""" front 4-pot radial mounted type with the dowel pin extensions. These are better designed than Brembo's calps
What are the specs on the LS430 calipers? What piston size? How does it compare to 951 fronts?
What are the dimensions of the Boxster S rotors?
I'm trying to get an idea for how much improvement these calipers and rotors would provide.
coctostan- Posts : 25
318mm Boxster S rotors
I will have to mic the piston...IIRC 4 x 42mm pistons
Rotors are 28mm wide.
According to my rough calculations, this caliper and rotor should have excellent balance with the 86 stock MC and the 18/5 prop valve. Do you guys know the width of the rotor's braking surface, the annulus width? I just guessed on that for my calcs.
I apologize if you guys had already done this math, but I couldn't find it anywhere.
Do you guys know if these calipers have stainless pistons? Are they a monobloc design? Has anyone purchased the remanufactured calipers that sell for around $85 each?
LS430 caliper specs
They are 4 x 42mm piston MONOBLOC ALLOY. That is why I chose them, they are an excellent match for the 944 Master Cylinders. I will be doing hydroboost or possibly a dual manual like 948 member did on the Gestapo board.
There are other calipers that are as nice (like Toyota Supra 4 pots). But of course you will pay nicely even if you can find them. I have the refurbed ones at 140/pr and I have rebuilt calipers before and these are new. The pistons are even new,so it's hard to tell if they are stainless. I haven't stuck a magnet to them, but higher strength stainless is usually magnetized because of the higher Fe % for strength/durability.
Hi, I was wondering if this swap will fit inside early offset, 15 fuchs? BTW nice to see everyone jumping over
tooms351- Posts : 50
Not likely, they are BIG - booyah!
(BTW - this is in comparison to the bigger 951 rear calipers, which I don't believe fit under early offset 15" Fuchs).
I'm gonna say no see pics below
rotor sitting on the face of a early 15x7 Fuch
and here is the space you have left without the caliper
Johnny, could you get me a width comparison of the 951 caliper vs the Lexus Caliper. By width I mean from the "Porsche" text to the opposite side of the caliper. I'm curious if there will be clearance issues with wheel spokes.
154mm for the rear 951 calipers, 162mm for the Lexus.
Thanks Johnny and Msmoorenberg, I do have 17" italian knockoffs ( very heavy ) for the street, but still run 15" fuchs for track days
More dims for wheel clearance questions
The 55mm dim on the lexus calps is the dim that I wanted to know on the Big Reds but never got a reply to.
Thanks for those dims. I have to say those Lexus calipers are stout. I guess stopping a massive luxury car is no easy task.
86 Turbo about to be cracked
Anybody have an 86 Turbo hub and Rotor to measure the dimensions. IT's the ODDBALL
Basically need to know the rotor dimensions to verify if all that is needed is to drill the bracket mount bolt spreadwidth to 94mm
What I,m concerned with is the rotor heighth being the same as the Early NA rotor height (NOT Width).
Hard to tell from the pics but what is critical is the dimension in yellow being same as the 83-85.5 NA......
Any input ???? .....PORH
oh im using 87 rotors which are the same as the 86 I THINK
still got my images? or did that thread get nuked (PORH)? I can try to find my photos and post them up here, everything mounted perfectly!
Tetzuoe- Posts : 178
"""""""""or did that thread get nuked (PORH)?""""""""
Yeah, They think I stole their Lexus Caliper on Boxster Rotor Idea and infringed on their Adapter Bracket design by posting for all the world to see!!!
PORH
PORH
Ill dig up my photos when I can find my camera cable.
Carbotech makes pads for the LS430 calipers
I checked a few manufacturers and Carbotech is the only one I could find that offers both street and track pads. You can get any of their compounds in this pad size.
Track pads
SCHWEEEEET. I am gonna see what it takes to drop the LS430's on the rear as well.....can't beat the price. I looked at a brand new set of Brembo 4-pots for a Mustang and they don't have anything on the Lexus calps....
» ls430 and rx7 brake swap wheel fitment
» Ultra's 86 951 LS430 brake upgrade
» What's the largest brake swap that will fit under 15" phone dials?
Page 1 of 10
Today at 5:14 pm by SpeedRacer11
Today at 4:30 pm by ThomasJoseph315
Yesterday at 11:12 am by Nath1142
Mon Apr 22, 2024 8:22 pm by lowform
Mon Apr 22, 2024 8:12 pm by lowform
