LT1 Spark Plug make and model
Hi All
Can you tell me what spark plugs you are using? I have a 95 LT1 which runs fine, I was just wondering if I have the optimum plugs for my application. Engine has been completely rebuilt and is managed by an Omex 7 series engine management unit so no Optiflex.
Also what gap are you setting, I have NGK plugs set at 0.028".
All comments and suggestions gratefully received.
Q
Q
Re: LT1 Spark Plug make and model
I run NGK T55 plugs gapped to .050" in my '95 LT1. Cheap and they work great. Mine is mostly stock except for a very mild cam and shorty headers. Still using Optispark.
Rob44- Posts : 37
quarterflash likes this post
I'll check which plugs I have. With that gap you must be getting a bigger bang.
Engine is stock apart from headers and a complete rebuild with bigger pistons and skimmed heads.
I'm using bosch injectors and Omex 710 engine management.
Q
Q
That .050" gap was what was recommended on the LT1 Camaro and Firebird forums when I looked into it. That's all I've ever tried.
Rob44- Posts : 37
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
