928 5-speed kit - Page 2 EmptyYesterday at 11:51 am by geegeesbits@gmail.com
928 5-speed kit - Page 2 EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
928 5-speed kit - Page 2 EmptySun Jan 26, 2020 4:51 pm by j7wolfe
928 5-speed kit - Page 2 EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
928 5-speed kit - Page 2 EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
928 5-speed kit - Page 2 EmptySat Jan 18, 2020 7:15 am by Rothaus
928 5-speed kit - Page 2 EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
928 5-speed kit - Page 2 EmptyThu Jan 16, 2020 2:11 am by Golten1986
928 5-speed kit - Page 2 EmptyTue Jan 14, 2020 2:48 pm by Gumby
928 5-speed kit - Page 2 EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
928 5-speed kit
Page 2 of 2 Previous  1, 2
928 5-speed kit - Page 2 Empty Re: 928 5-speed kit
Post  erioshi on Sat Nov 15, 2014 4:11 pm
xschop wrote:Sounds like you need a 4wd not a hybrid. Yes you can space sway bar forward and down, but forget about lowering car at that point.
I have the one last LS 5 speed kit that I'll build this year. My oilfield parts have me busy for quite awhile.....Drill baby, drill
Thanks for the info, I'll have to see where the budget is at.
It's not a hybrid, lol.  Just a basic high fuel-mileage box SUV for when I'm not interested in driving the real 4x4 pick-up.  The pick-up is great for towing, but it's mileage as a commuter would be absolutely punishing for the majority of my driving.  I put so many miles on my commuters that fuel mileage can actually make a real difference in the economics of ownership.
haroldk wrote:You should just see if Justin can still get snows in your size.
Thanks for the suggestion.  For me selling the Jag is actually more about getting out of it while I'm still money ahead than anything else.  I'd rather put that money into the 928 than watch it slowly disappear in an aging Jag.  With the 928 for a summer toy, the Jag is mostly just baggage.
erioshi
erioshi
928 5-speed kit - Page 2 Empty Interested,
Post  Godspeed! on Wed Jan 14, 2015 5:20 pm
Just came across this. Appears to be a quality alternative. Is it still available. Will be used in a 78 928 5spd.
Godspeed!
Dave
Godspeed!
Post  xschop on Thu Jan 15, 2015 1:14 pm
Yes, although I sold my LS1-928 and started the V12 hybrid, I still make this kit, just PM for details.
Post  Godspeed! on Fri Jan 16, 2015 9:52 am
Ok. Great, figuring out how to PM here , different......
Basically an LS motor ( not quite sure which one, will be budget dictated) car is a 1978 5 Spd.
Well, let me see if I can now PM you.....
Godspeed!
dave
Godspeed!
Post  Godspeed! on Fri Jan 16, 2015 9:59 am
Geesh seems like you are required to have some number of posts before one is allowed to PM?
Ok, my e-mail is delmtsp at aol dot com..
Godspeed!
Dave
Godspeed!
Post  erioshi on Thu Apr 23, 2015 12:05 am
It looks like I forgot to say "Thanks for the kit!" in here. My kit looks good and hopefully I can get back working on my 928 soon. Still need a few more bits before I can start swapping.
However, I've also been talked into helping a friend put a 383 LT1 into a 928 5-speed he just picked up. The OE Porsche engine is DOA, and I'd like to work with your kit for this swap because he may change his mind (again) at some point and decide to change over to an LS mid-swap. I know you mentioned needing a spacer (.4" ?) with the LT1, but was that with a C5 two piece bell housing or with a C4 6-speed bell housing? We have a ZF 6-speed on hand with the OE bell housing. I just have not had time (and enough warm weather) to get the LT1 off the engine stand and and start test-fitting things.
Thanks!
erioshi
erioshi
Post  xschop on Sun Apr 26, 2015 3:21 pm
You would need to add 0.40" plate between C5 bell housing adapter plate and retention tube to fit an Lt1.
Post  erioshi on Sun Apr 26, 2015 11:09 pm
Thanks! Exactly the information I was looking for.
erioshi
erioshi
Post  dozman on Thu Sep 10, 2015 5:25 pm
Rob can you give me an email. Have a few questions and a kit for an auto.
Psi_101 at hotmail dot
com
Thx,
John
dozman
Post  xschop on Mon May 01, 2017 3:08 pm
I've got 2 adapter plates and extention tubes ready to go. Engine mounts not included but I will email tech drawing as they are easy to make.
$385 shipped US-48 only. Just PM
Post  erioshi on Tue May 02, 2017 11:31 pm
Mind dropping me an email or PM with the drawings? I still need to put a set of engine mounts together for the race car. I figure working from the drawings should be more precise than trying to copy an existing set of mounts.
erioshi
erioshi
Post  xschop on Wed May 03, 2017 8:02 pm
Shoot me an email at [You must be registered and logged in to see this link.]
I'll send you the pic as I don't have scanner at shop ok.
And again, you can mount the 928 automatic with these adapters. You need to get the 928 AUTO front coupler and mate it to Chevy flex plate.
The 928 Auto is a super strong Mercedes trans FYI.
928 5-speed kit - Page 2 Empty any more 928 LS kits or parts left?
Post  Gumby on Tue Jan 14, 2020 2:48 pm
xschop, do you have any parts left? If not how about tech drawings?
Gumby
