LS430 Big Brake Swap
+34
Tehone
Psychoideas
mvallee
Vic-S2V8
87wolfsburg
laptop_geek
gamman
Walkerhiboost
Bluemach1
Bluemongoose
adam7e
modenas
subterfuge
kelleysj
Ender751
Vorsche944
jimbo93
m73m95
968gene
Tetzuoe
tooms351
coctostan
msmoorenburg
Johnny Johnny
38 posters
Page 6 of 10
Page 6 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Re: LS430 Big Brake Swap
Yeah, did the LS430 Calipers fit up under the 16" Fuchs?
Hmmm...... $72 Lexus monoblock Caliper
$3-400 crossover-tube Brembo
That is a tough one!
kelleysj- Posts : 194
the only issue with fitting a 16" wheel over them on an early car such as the fuch is you need a spacer due to the taper inside from the face of the wheel other wise its minimal clearance, but it works
jimbo93- Posts : 14
xschop- do you sell (or would you) the adapter rings for the boxS rotors for late cars? I could handle the caliper mounts, but I'd prefer some level of precision for the rings.
To be perfectly honest even the early cars could use those rings. Mine has a slight bit of vibration to it @100+ and I think it's because the rotors are not dead centered.
Dawgz83948- Posts : 603
No, I will not do a set-up just for rings. I'm working on some bike stuff on my lathe ATM, sorry
If you want a complete set of the late adapters and rings just PM me
Why don't the lugs hold the rotors centered, like they do on every other car?
m73m95- Posts : 77
Most cars have the rotors centered on the hub...?
if you got a ford or checy, next time you take the brake pads off look at the rotor, all it takes is a nice hammer all the way around to move it up then it off for servicing.
modenas- Posts : 285
The Early 944 Hubs are a tad wide at the rim for the Boxster S rotor and need to be trimmed.
The Late 944 Hubs hold the 282mm NA and 299mm Dia. Turbo rotors centered at the rim in 5 points, the Boxster S rotor hat is too large to fit snug on the LATE hub, reason for the centering rings. I am rethinking the EARLY Boxster S swap at the moment. I would like to find a rotor that slips right over the hub with no machining, but it's like pulling teeth over at the $hitlist....
4" Dia. Billet Rod is not cheap and wastes alot of chips to get the rings machined....
Even an early after machining the hub needs those rings. I'm getting a couple machined right now (since my car is at my mechanics sorting the brakes) to install on my car. The issue is there is still a bit of play even after machining the hubs and I'm getting some vibration at higher speeds.
Your Machinist should be slip-fit testing your Early hubs to your inner rotor circumference. The drawing I posted for the Early hub machining is dead-on for R1 Concepts Brand Boxster S rotors. For the Early 944 HUB and Lexus Calipers I am thinking about building bolt-on hats that bolt to Wilwood Light-weight rotors. There will be no machining of the Early hub needed.....
http://www.revolutionbrake.com/precisionimages/ul-32-directional-vane-rotor-lg.jpg
I'm sorry, I can't remember the name of the company, but one of the rennlist brake vendors makes hats for early offset cars.
They allow people with early offset cars to use big black brakes (which use the same boxster S/996 rotors that we are using)
$$$$$$ though! (something like $400 for the hats, and another $200 per rotor)
m73m95- Posts : 77
I am seeing those at about $65 apiece (and only $118 for the turbo rear pair), anybody have a line on the ls430 calipers for less than $180 w/ core?
I may be able to cook something up... I'll keep posted
adam7e- Posts : 63
well, I just went ahead and ordered them from rock auto. I wasn't going to save that much off of 180 anyway.
Sorry about the delay, I asked a friend from ToyotaNation to check into it, he can't beat that price at this point. He happened to stumble upon some 4-pot twin turbo supra calipers, but could only get one side at the ridiculous price. Grabbed em' anyway and now looking for the other side to have a few pairs on the cheap. I'll have to check into whether or not they can be used. I think he has some lying around from the LS400 but that probably won't work either.
adam7e- Posts : 63
The LS400 and Supra calipers are AXIAL mounted and won't work with the adapter diagram I posted and that is in greg's manual....LS430 Monoblocks are RADIAL mounted at 130mm bolt centers.
Off to the supra/toyota forums they go for sale then. The twin turbo brakes are popular for the toyota guys to swap to if they can find em, so I'm sure these won't last too long. Looks like I'm back on the prowl for cheap or free ls430 calipers
adam7e- Posts : 63
You should go to: http://www.craiglook.com
Search "LS430 Parts"
I came up with three totalled cars. I'm sure you can get a nice used set for $100 or so.
Edit, here:
http://atlanta.craigslist.org/atl/pts/1719099159.html
http://dallas.craigslist.org/ftw/pts/1685779290.html
Both clearly have the calipers still on there!
~Chris
Edit, here:
~Chris
You guys better start collecting these... The Peugeot guys are buying 944 Early adapters for the 505 Turbo and Rock Auto is dwindling on their supplies.... I'm working with a guy to stick them on an IROC Camaro in the next couple of weeks.....
For Reals........1987 Peugeot 505 Turbo front swap.....
I bet they get real tired of being asked about their Toyota Corolla's.
When someone asks me what I'm driving, I'll just answer "a lil' bit of everything"
I still haven't decided how I want to go about mounting the Hyandai Tiburon mirrors LOL
Got my R1 slotted/drilled rotors, they look great. My rock auto calipers (I went with the set of 2 front, loaded) should be here soon. Looking forward to get this all put in, but my back is not cooperating. I still owe some manual steering tie rod ends to Admin so he can create the bump steer kit, but there has been no way I could physically make that happen short of taking them off in place, which I may do. Also looking forward to these adapters.
Wow, the LS430 calipers are really impressive! Coupled with the Boxster S rotors, it looks to be quite a jump in size.
» ls430 and rx7 brake swap wheel fitment
» Ultra's 86 951 LS430 brake upgrade
» What's the largest brake swap that will fit under 15" phone dials?
Page 6 of 10
