» Adapter plate
LEAKING TPC HYDROBOOST EmptyThu May 02, 2024 9:35 am by sepheroth86
LEAKING TPC HYDROBOOST EmptyWed May 01, 2024 8:32 am by Rob44
LEAKING TPC HYDROBOOST EmptyTue Apr 30, 2024 8:28 am by JW1970
» Parts availability for general maintenance?
LEAKING TPC HYDROBOOST EmptyMon Apr 29, 2024 10:36 pm by zenon
» What coilover spring rates are you running with torsion bar removed?
LEAKING TPC HYDROBOOST EmptyMon Apr 29, 2024 10:24 pm by zenon
LEAKING TPC HYDROBOOST EmptySun Apr 28, 2024 9:38 am by SpeedRacer11
LEAKING TPC HYDROBOOST EmptySun Apr 28, 2024 12:00 am by Raymond-P
LEAKING TPC HYDROBOOST EmptySat Apr 27, 2024 11:09 pm by Raymond-P
» Rear coilover suspension setup
LEAKING TPC HYDROBOOST EmptyFri Apr 26, 2024 3:30 pm by ThomasJoseph315
LEAKING TPC HYDROBOOST EmptyMon Apr 15, 2024 6:59 pm by JW1970
May 2024
6789101112
13141516171819
20212223242526
2728293031
LEAKING TPC HYDROBOOST Empty LEAKING TPC HYDROBOOST
Post  lowform Mon Apr 22, 2024 7:22 pm
Hello friends,
I am chasing my next issue.   The TPC hydroboost leaks at the aluminum block where it mates to the side of the hydroboost.   I have replaced my o-ring (per Ray's legendary post) as I had the incorrect size originally.  However, the hydroboost continued to leak a small amount.   Last weekend I took the aluminum plate off one more time and installed yet another large o-ring along with a new copper crush washer.  It now leaks even worse.   I can actually see hydraulic fluid running down the bottom of that aluminum block and dripping onto my steering joints and headers.  I am confident both o-rings are seated properly and the large bolt is tight.   Had anyone else experienced this?  If so, do you have a solution you could recommend?
Thank you,
Aaron
lowform
LEAKING TPC HYDROBOOST Empty Re: LEAKING TPC HYDROBOOST
Post  Raymond-P Sat Apr 27, 2024 11:46 pm
Aaron,
I feel your pain!!  Unfortunately disassemble will be required again.
First...you CAN have an O-ring that is too big so you want to go back to the correct size.
Make sure the high pressure O-ring (the larger one) is a new Nitrile Rubber unit that is 7/8" OD / 11/16" ID x 3/32" thickness.
You will also need yet another new copper crush washer for the banjo bolt.
I suspect that a small piece of debris may have found its way into the O-ring seat or somewhere on the interface surface when you first replaced the incorrect O-ring.  You'll want to check for that after removing the oversized O-ring.  It is absolutely imperative that that all assembly components are spotless. This includes the mating surface on the HB itself.
While you have it all apart....take a good look at the aluminum adaptor and check for any abnormalities such as debris, scratches, gouges, or maybe even a crack.  Also make sure the mating surface is truly flat.
I hope one more go-around is all you need!!  Let us know how it goes.
Raymond-P
Raymond-P
Post  Rob44 Wed May 01, 2024 8:32 am
My Hydroboost is leaking as well. I'm pretending that it doesn't for now.
Rob44
