LS430 Big Brake Swap
+34
Tehone
Psychoideas
mvallee
Vic-S2V8
87wolfsburg
laptop_geek
gamman
Walkerhiboost
Bluemach1
Bluemongoose
adam7e
modenas
subterfuge
kelleysj
Ender751
Vorsche944
jimbo93
m73m95
968gene
Tetzuoe
tooms351
coctostan
msmoorenburg
Johnny Johnny
38 posters
Page 3 of 10
Page 3 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Re: LS430 Big Brake Swap
It looks like the S2 mounting is going to be the 76mm / 3.0", similar to the Late Turbo. I meant to say S2 M030 in the previous post...
Yea, OOPS. (I'm not perfect, just damned close...)
gt1scca- Posts : 795
They are on, and bled (best as I can tell). Has anyone noticed a slightly softer pedal, or am I needed to bleed them more. I used a Motive power bleeder and had my wife pump the pedal.
Dawgz83948- Posts : 603
What MC are you using? (944 manual, Turbo, Wilwood...?)
Using Porsche Master with BMW hydroboost.
23.81mm ~ 15/16" bore.
Hmmm. Not claiming to be an expert in fluid dynamics, but from research thus far, 15/16" bore with the LS430 calipers may be near the upper limit (MC size). 5/8" - 7/10" bore should be great on the manual system using dual MCs...15/16" would be better suited to the rear circuit. The hydroboost will seem to mask MC sizing issues, but you will "feel" it in the pedal.
Even so, that '83 should outbrake most things it outruns...
How does it stop? Any rear lockup under hard braking?
gt1scca wrote:23.81mm ~ 15/16" bore.
No, fronts do though, just clamps the 235's to a dead stop.
Then what's the problem?Dawgz83948 wrote:No, fronts do though, just clamps the 235's to a dead stop.
The LS430 has more piston volume, R1 rotor=more swept area...bla, bla, bla. You may have biased your rear brakes into "sleepyville"...
23mm MC has a .75" rear bore...manual setup with Turbo fronts on rear ~ 15/16" - 1" bore...(again, "boosted" may compensate for sizing diff., although rear bore is probably close, depending on rear components...)
Rear prop. valve? (944, 944T / S2 ?) Switching to the 15/8 valve may help.
gt1scca wrote:Then what's the problem?Dawgz83948 wrote:No, fronts do though, just clamps the 235's to a dead stop.
I guess the big issue for me is that the pedal travel is rather far (3/4 of the way down) which makes me uneasy. I'm going to drive it around a bit and see if I get used to it.
I think I figured it out, in my tweaking of the hydroboost the push rod in the booster going into the master was "trimmed". I welded a tip back on it to make the puhrod a little longer and I have a much higher pedal. Anyways, I hate doing anything brake related on this car, it burns off tranny fluid and/or brake fluid forever.
Sweatin' me, dude...
Basically, not enough stroke @ the MC = not enough fluid movement / pressure, same as wrong size MC. I learn something new daily...
Glad you got it. Awesome.
Here's something else I learned...
When sizing master cylinders for the Tilton dual MC setup, pedal ratio is a major part of the equation. I had thought the 944 stock ratio was 5:1...until I got the dims from an actual pedal.
Here's the results...
The stock MC pushrod location = 4.25:1 ratio.
The .75" higher modified location (used in the booster delete / single manual MC setup) = 6:1 ratio.
(The MC pushrod mounting point would have to be raised ~1.1" to achieve a 7.6:1 ratio...)
Recalc
Hey Greg, So if the Pedal ratio is 4.25:1 then should BOTH MC's be recalc'd for a larger Diameter since there will be less pedal travel (Lexus fronts and rear)?????
What is a bonus about the Dual MC housing is the fact that it has the heim-joint pushrod so drilling the pedal for a different ratio won't cause binding worries.
Also the "Z" measurement taken should be exactly in the middle of the pedal
Yes...correct...and, it was.
I'll call Mike @ Tilton shortly, for sizing with the stock (4.25:1) and relocated (6:1) ratios. My last data submission was with the 6:1 ratio...
gt1scca wrote:Yes...correct...and, it was.
Are you proposing the option of a manual setup with the 4.25:1 pedal ratio? If so, that will require some very significant pedal force with a car this heavy. Most passenger cars give an effective boost (pedal ratio + booster ratio) in the 6:1 range. I don't think there is any use trying to get the 4.25:1 ratio to work. Maybe Tilton will have some insight on this.
coctostan- Posts : 25
4.25:1 Ratio:
FRONT MC = 5/8"
REAR MC = 15/16"
Estimated pedal pressure = 150 lbs.
6:1 Ratio:
FRONT MC = 7/10"
REAR MC = 1.0"
Estimated pedal pressure = 80-90 lbs.
Using the stock MC pushrod location is possible, but is not advisable...Also, the 4.25:1 ratio will exert significantly greater stress on the firewall.
*The 6:1 ratio is achieved by moving the MC pushrod mounting up the pedal 3/4"...
FRONT MC = 5/8"
REAR MC = 15/16"
6:1 Ratio:
FRONT MC = 7/10"
REAR MC = 1.0"
Yeah, 150lbs of pressure would get old fast. I think lots of people complain about manual brakes because they aren't properly setup. If we have adequate clamping force, appropriately sized MCs and enough pedal leverage we should have a nice setup.
ratio
It is actually better that the pushrod be moved up 3/4" to 1" because this will give even more clearance from the valve cover and now the 2312 modified header.....
For those of you willing to "guinea pig" the +1.1" MC pushrod relocation mod...
7.6:1 Ratio:
FRONT MC = 5/8"
REAR MC = 15/16"
7.6:1 Ratio:
FRONT MC = 5/8"
REAR MC = 15/16"
Hey guyz I finished and want to post a pic. I left the water shield on the rear of the rotor. Seemed to fit fine, just had to cut a bit.
gt1scca wrote:Tim, is your car down? If not, send me some dims...
Gonna bring it to work and mic it out as well as some pics to post. I also have the bearing P/N's used in it.
Awesome.Dawgz83948 wrote:Gonna bring it to work and mic it out as well as some pics to post. I also have the bearing P/N's used in it.
Wheels / brakes look great!
M030 UPDATE
I finally have a set of Turbo S spindles in hand. RADIAL MOUNT TABS
Looks like a 77mm offset rotor (late Turbo) and the LS 430 4-pots with the dowel pins shaved will fit the M030 spindles
The real quest would be to find a 77mm offset rotor with 315-330mm Diameter, 28 or 32mm Rotor sweep width.
So basically any Late spindle (non M030) with the LS430 calipers and Boxster S rotors trumps the M030 set-up IMO.
Copied from PP..... Looks like a 965 rotor would do the trick.......
*****************Might be of use? upgraded my 968 to 993TT brakes.
DISCS for use with Big Red or Big Black type calipers (all 322mmx32mm)
965 (911-964 3.6 Turbo)
1-piece disc, cross drilled, 45mm top hat
965-351-045-00
965-351-046-00
928 GTS
1-piece disc, NON cross drilled, 45mm top hat
928-351-045-01
928-351-046-01
993 Twin Turbo
2-piece disc, cross drilled, 40mm top hat (separate disc and mounting ‘hat’)
993-351-045-10
993-351-046-10
discs are seldom used, 993RS cheaper
993RS
1 piece disc, cross drilled, 40mm top hat
993-351-045-00
993-351-046-00
DISCS for use with M030 (928 S4) calipers (all 304mm x 32mm)
968 M030
965-351-041-01
965-351-042-01
928 S4
928-351-045-01
928-351-046-01
Discs with a ‘top-hat’ (offset) dimension of 45mm will have an outer disc pad face in the same position as standard – the larger discs are thicker (32mm vs 28mm) therefore the inner pad face of the discs are 4mm further in (into the car). This will close the gap between the disc face and the track rod end – it has been suggested that heat build up from the disc can be a problem, but I have never heard of any actual experience of this.
Discs with a ‘top-hat’ dimension of 40mm will have an outer disc pad face 5mm further out than standard (also pushing the caliper further out by 5mm and closer to the spokes of your wheels). The inner pad face of the discs will be –1mm further out from standard (further out of the car) and hence remains virtually the same distance from your track rod end.
NOTE: the M030 spindle/hub assembly locates the disc approximately 3mm further out to compensate for the additional thickness of the discs from standard.
CALIPERS
Big Reds (993 Twin Turbo calipers)
993-351-425-10
993-351-426-10
36mm/44mm piston sizes
Leading, radial mounting, bleeder screws & cross-over tubes require swapping over for trailing mounting. Pad retention springs will be upside-down. Red in colour.
Big Blacks (928GTS calipers)
928-351-423-03
928-351-424-03
Trailing, radial mounting, bleeder screws & cross-over tubes in correct position. Pad retention springs in correct orientation. Black in colour.
M030 calipers (928 S4 calipers) (also used on 944 S2 M030, 944 Turbo S)
928-351-421-03
928-351-422-03
Trailing, radial mounting, bleeder screws & cross-over tubes in correct position. Pad retention springs in correct orientation. Black in colour. Note: depending what year car these are from, the piston seal/dust seal design can differ. The older design is less robust/efficient. The later design is the same as that used on the Big Reds/Big Blacks. For these you can either use the standard 968 M030 dross drilled discs or the 928 S4 NON cross drilled discs. Both are the same size and offset.************************************************************
965-351-045-00
965-351-046-00
928 GTS
928-351-045-01
928-351-046-01
993 Twin Turbo
993-351-045-10
993-351-046-10
993RS
993-351-045-00
993-351-046-00
968 M030
965-351-041-01
965-351-042-01
928 S4
928-351-045-01
928-351-046-01
CALIPERS
993-351-425-10
993-351-426-10
928-351-423-03
928-351-424-03
928-351-421-03
928-351-422-03
xschop wrote:I finally have a set of Turbo S spindles in hand...
Be gentle, I paid way too much for them.
968gene- Posts : 259
thought he was talking about mine
I have an extra set now, they werent thaaat much.
Tetzuoe- Posts : 178
Considering that NA spindles are $75 for a pair...
» ls430 and rx7 brake swap wheel fitment
» For Sale: NA LS430/Boxster S big brake kit
» What's the largest brake swap that will fit under 15" phone dials?
Page 3 of 10
Today at 7:44 pm by Raindoc
» Turbo Transaxle wanted
Today at 5:26 pm by Raindoc
Yesterday at 4:06 pm by Rob44
Wed May 01, 2024 9:32 am by Rob44
Tue Apr 30, 2024 9:28 am by JW1970
Mon Apr 29, 2024 11:36 pm by zenon
Mon Apr 29, 2024 11:24 pm by zenon
Sun Apr 28, 2024 10:38 am by SpeedRacer11
Sun Apr 28, 2024 1:00 am by Raymond-P
Sun Apr 28, 2024 12:09 am by Raymond-P
