LS 982 5speed project here EmptyYesterday at 8:32 am by Rob44
» Adapter plate
LS 982 5speed project here EmptyYesterday at 8:28 am by Rob44
LS 982 5speed project here EmptyTue Apr 30, 2024 8:28 am by JW1970
» Parts availability for general maintenance?
LS 982 5speed project here EmptyMon Apr 29, 2024 10:36 pm by zenon
» What coilover spring rates are you running with torsion bar removed?
LS 982 5speed project here EmptyMon Apr 29, 2024 10:24 pm by zenon
LS 982 5speed project here EmptySun Apr 28, 2024 9:38 am by SpeedRacer11
LS 982 5speed project here EmptySun Apr 28, 2024 12:00 am by Raymond-P
LS 982 5speed project here EmptySat Apr 27, 2024 11:09 pm by Raymond-P
» Rear coilover suspension setup
LS 982 5speed project here EmptyFri Apr 26, 2024 3:30 pm by ThomasJoseph315
LS 982 5speed project here EmptyMon Apr 15, 2024 6:59 pm by JW1970
May 2024
6789101112
13141516171819
20212223242526
2728293031
LS 982 5speed project here Empty LS 982 5speed project here
Post  LS982 Wed Apr 10, 2024 10:21 pm
Hello friends,
Thank you for the great forum. I was recomended come to here from Rennlist forum.
I have 1982 982S 5-speed with burnt engine harness and engine what I have never seen running. So it is quite easy decision to go with LS.
few questions.. ( yes I saw the search button Cool  )
Does the weight ratio of the car suffer too much with all aluminium LS3 ?
How the stock  5 speed survive with C6 430 hp LS3 in street ?
LS982
LS 982 5speed project here Empty Re: LS 982 5speed project here
Post  Raymond-P Sun Apr 14, 2024 3:07 pm
LS982,
From what I can gather, your 928S V8 engine weighs in at 260 Kg (573 lbs.) according to the Porsche Manual.  I presume that's complete with accessories.
CORRECTION:  I thought 982 was a typo for "928."  My bad!  The 3.4L 982 Boxster engines weighs in at just under 400 pounds including the flywheel.  (Someone actually weighed it!)
Below is what the LS1Tech guys have to say about the LS3 as of Feb 26, 2020
Length: 26.08 inches
Height: 28.89 inches
Width: 29.05 inches
Weight: 430 pounds (with accessories). GM 6.2-liter LS3 V8
As for the transaxle holding up under LSX HP, the conventional wisdom (for the 944 anyway) is to go with a turbo model transaxle, add a case reinforcement plate, never drop the clutch, and refrain from speed shifting.  Under these conditions, 500 BHP is sustainable.  Of course...every set up is a bit different and every driver is a bit different, so results will vary.
I'm sure a few more forum folks with more street & track experience in there 948's will chime in!
Last edited by Raymond-P on Sun Apr 14, 2024 3:28 pm; edited 1 time in total (Reason for editing : Correction)
Raymond-P
Raymond-P
LS982 likes this post
Post  LS982 Mon Apr 15, 2024 12:17 am
Raymond-P wrote:LS982,
Width: 29.05 inches
Hello... Yes IT IS TYPO!!! Whan an idiot I have been.. Even my forum nick is wrong... pale
Yes the car is 1928 928 S 16 valve 4.7 litre V8.
Sorry!!!!!!!
LS982
Post  Raymond-P Mon Apr 15, 2024 9:51 am
No worries... typos are the easiest thing to fix!  Smile
Raymond-P
Raymond-P
