» Adapter plate
Best engine uprights/plates EmptyThu May 02, 2024 9:35 am by sepheroth86
Best engine uprights/plates EmptyWed May 01, 2024 8:32 am by Rob44
Best engine uprights/plates EmptyTue Apr 30, 2024 8:28 am by JW1970
» Parts availability for general maintenance?
Best engine uprights/plates EmptyMon Apr 29, 2024 10:36 pm by zenon
» What coilover spring rates are you running with torsion bar removed?
Best engine uprights/plates EmptyMon Apr 29, 2024 10:24 pm by zenon
Best engine uprights/plates EmptySun Apr 28, 2024 9:38 am by SpeedRacer11
Best engine uprights/plates EmptySun Apr 28, 2024 12:00 am by Raymond-P
Best engine uprights/plates EmptySat Apr 27, 2024 11:09 pm by Raymond-P
» Rear coilover suspension setup
Best engine uprights/plates EmptyFri Apr 26, 2024 3:30 pm by ThomasJoseph315
Best engine uprights/plates EmptyMon Apr 15, 2024 6:59 pm by JW1970
May 2024
6789101112
13141516171819
20212223242526
2728293031
Best engine uprights/plates Empty Best engine uprights/plates
Post  Nath1142 Thu Apr 25, 2024 10:12 am
Who makes the best engine plates/uprights? Are they all the same? I have most stuff for the swap already and was debating fabbing the engine mounts from the wiki site, half cause I like fab work and half cause I live in Canada and our dollar to us is awful right now so I avoid getting stuff shipped up as much as possible. But I wanted to see if anyone TPC, all Porsche racing, anyone else has done any revisions to there mounts over the years to make them better then just the older style.
Nath1142
Best engine uprights/plates Empty Re: Best engine uprights/plates
Post  Raymond-P Sat Apr 27, 2024 11:31 am
Nath1142 wrote:Who makes the best engine plates/uprights? Are they all the same? I have most stuff for the swap already and was debating fabbing the engine mounts from the wiki site, half cause I like fab work and half cause I live in Canada and our dollar to us is awful right now so I avoid getting stuff shipped up as much as possible. But I wanted to see if anyone TPC, all Porsche racing, anyone else has done any revisions to there mounts over the years to make them better then just the older style.
I can vouch for the TPC units.  Well made with a nice powder coat finish, and fit perfectly.  Working flawlessly in my project.  Kent has upgraded them from the originals with more durable bushings.
Raymond-P
Raymond-P
Post  Nath1142 Sat Apr 27, 2024 12:39 pm
I see there running a poly insert bushing instead of the old school engine isolator. Which 100% agree that’s an upgrade have they change dimensions overs the years? Or is everything pretty much just based of the originally dimensions. Do the Tpc ones allow for AC?
Nath1142
Post  Raymond-P Sat Apr 27, 2024 11:09 pm
The TPC mounts do not interfere with AC components.
I installed the engine on the front crossmember and then installed a new Dirty Dingo Low Mount AC Kit before raising the engine assembly into the car.  You can check out the details at the link below.
AC Compressor Replacement
Raymond-P
Raymond-P
