Gregg Sloan
+15
alienwerke
Marky522
expuppy
Luke714
Bluemach1
modenas
aixgelo78
19 posters
944Hybrids: 924/944/968 and 928 V8 Conversions :: Board Related News :: Customer Service Area- The Good and Bad Service
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: Gregg Sloan
Where did you get the M12 x 1.0 Banjo Bolt?
Re: Gregg Sloan
Here ya go, ordered it late last week, arrived already today:
aixgelo78- Posts : 182
Re: Gregg Sloan
you stuck the crush washer between bolt, banjo, and master right?
modenas- Posts : 285
Re: Gregg Sloan
Yes sir I will....haha, Im not that much of a noob. I just didnt know crap about 951s and LS1s when I started this project.
Re: Gregg Sloan
ok at least ur doing it right, what brake master are you using?
Re: Gregg Sloan
and ur making a new resivor for the clutch master?
Re: Gregg Sloan
If anyone needs any parts I might be able to do some machining around Christmas for free if you send me material. It's the least that I can do after all the help you guys have given me! It's looking good, once you get the engine mounted in the car the rest goes easier when you can see the light at the end of the tunnel.
Luke714- Posts : 441
Re: Gregg Sloan
I thought that was just visions of the red and blue lights in my rear view. LOL
Re: Gregg Sloan
could be that too, if I have to get pulled over in something I would like to be my 948 though
Re: Gregg Sloan
for clutch master, i used the brake reservoir from Honda 1000 motorcycle. Just the right size, inexpensive and looks good too. just my two cents.
expuppy- Posts : 56
Re: Gregg Sloan
For clutch reservoir i am using the 996 911 turbo clutch reservoir , I like it because it uses the same cap as our brakes so my pressure bleeder will do both. Im going to use two of the reservoirs, clutch and brake.
Mark
Mark
Marky522- Posts : 175
Re: Gregg Sloan
Those are some good ideas....Im gonna check ebay now to look for them....
Ill try to work on it during the weekend again.
Thanks for all the input guys. I do wish to have AC, so if you are ever ready to make the brakets, hit me up and Im in.
Re: Gregg Sloan
I got mine free off an 80's F250, looks almost identical to the wilwood reservoir and works great.
Re: Gregg Sloan
Question.....
What is the AN fitting on the Moroso 20140 Oil Pan. I have hoses and fittings that thread into it that I got from Gregg, But I was never sent the Oil Filter adapter. Im basically trying to figure out what oil filter adapter I need. I was advised he had it, but again, was never sent.
TIA
Chris
TIA
Chris
Re: Gregg Sloan
The Moroso pan uses 10 AN fittings.
Re: Gregg Sloan
Check out the Billet Ebay adapter I found with -10AN fittings and oil pressure/temp sender tapped......
Re: Gregg Sloan
Re: Not so much about Gregg Sloan any more, thread!
LOL....Actually it is...Im sourcing out parts that I never received. As I source them out, I am showing where I got them and hopefully helping the next guy.
[/quote]Check out the Billet Ebay adapter I found with -10AN fittings and oil pressure/temp sender tapped......
[quote]
Thanks!
xschop approved
Re: Gregg Sloan
Just bought it. Thanks..... 1 more less thing I have to buy. Pretty soon I have to buy everybody in this forum some beer.
**edit, I can still use a LS1 oil filter?
Re: Gregg Sloan
The adapter they sent me said LT1 specific which I assumed was a PH8 filter threading. However I got the M20 x 1.5 threaded insert with the kit and researched Wix 51324 which is a better quality filter for a V8. Have been running it with absolutely no problems
EDIT: or Fram PH2921 which is the equivalent of PH8 but has the M20 x 1.5 threading
Gregg Sloan
I understand that you have a situation with the parts owed to me. That is fine, I cannot wait any longer hence me buying the parts myself.
You have in your hands my 951s engine harness, and LS1 engine harness. I would like those back. I would like it completed as per payment. I do not see a financial issue why you could not finish those, since it is just labor.
~Chris
~Chris
harnessing the harnesses
Wow, this sounds just like my harness situation with Greg Sloan. I was told I would recieve it in the mail after paying for the modification, getting the run-around, then he promised to return it un-modified as he is injured and still no sight of it after more than a year at that.
» What's happening with Greg Sloan
» When was the last time anyone had any contact with Greg Sloan?
Page 2 of 4
