Honda k24 swap
+15
Colibri Green
swift5508
Vlad
Dragonist
ajulka123
ptkorson
Dominicandude
Stuey86porsche944
s2k944alan
SilverLined
jso944
87944turbo
slow_944S
89EFhatch
19 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Honda k24 swap
Vlad wrote:Hello good to see how this build is going. I currently have one about 60% done was stuck on front cross member but some solutions are in the works. Any with questions feel free.
Where can we find more info, have you joined the Facebook group “Porsche k swap” there is a lot of info there? What did you do for bell housing, clutch and flywheel?
Can you just cut and reinforce stock crossmember, or maybe a different oil pan set up?
Any photos?
ajulka123- Posts : 5
Re: Honda k24 swap
Ok so I'm having a little trouble with this forum but I'll give some insite on what needs to done. I have an adapter plate fabbed to use the stock bell housing and tourque tube to the transaxel. If someone is interested I arrange to have one fabricated. The cross member has to be cut and the rack needs to be moved about 4 1/2 inches forward. The nubbs where the old motor mounts sat can be use to hold new custom mounts. I fabbed a set and they work great. Back to the cross member I currently working with a fabber to give me some fresh ideas as i my first few tries to create a loop where the oil pan sits didn't go well. Using hondata ECU, 3582ebay turbo, cluchmasters fabbed a pressure plate and throw out bearing to fit the stock Porsche bell. Using stock Honda starter.
Vlad- Posts : 7
ajulka123 and Colibri Green like this post
Re: Honda k24 swap
Vlad wrote:Ok so I'm having a little trouble with this forum but I'll give some insite on what needs to done. I have an adapter plate fabbed to use the stock bell housing and tourque tube to the transaxel. If someone is interested I arrange to have one fabricated. The cross member has to be cut and the rack needs to be moved about 4 1/2 inches forward. The nubbs where the old motor mounts sat can be use to hold new custom mounts. I fabbed a set and they work great. Back to the cross member I currently working with a fabber to give me some fresh ideas as i my first few tries to create a loop where the oil pan sits didn't go well. Using hondata ECU, 3582ebay turbo, cluchmasters fabbed a pressure plate and throw out bearing to fit the stock Porsche bell. Using stock Honda starter.
Yes I would like to know how to get a adapter plate and custom mounts, what is the best method to contact you? I sent a friend request but I can’t Message you.
Re: Honda k24 swap
Look for my IG page VladyBuilds
Vlad- Posts : 7
lukedanwarner@gmail.com likes this post
Re: Honda k24 swap
Vlad wrote:Look for my IG page VladyBuilds
Done look out for my message! Thank you kindly sir.
Re: Honda k24 swap
Do you have an update on this project? I'm just starting this same swap. I'm undecided on maintaining the torque tube and transaxle vs dropping s2k trans and rear instead.
swift5508- Posts : 1
Vlad likes this post
Re: Honda k24 swap
Hello from Australia,
This is an extremely interesting thread, great work paving the way 86 and Vlad.
I was wondering if the kmiata oil pan package could open up some crossmember options? Eg running either the crossmember (and maybe the rack?) through the central cut out?
At least you’d know the windage is battle proven.
Colibri Green- Posts : 5
Re: Honda k24 swap
Vlad - very cool build. Can you post more pics of the sweet wide body kit? What brand is it? Did it come with the car or did you mount? How much wider wheels can you fit with the wider flares? Sorry for the 20 questions! Great looking car so far.
86-944- Posts : 1
Re: Honda k24 swap
86-944 wrote:Vlad - very cool build. Can you post more pics of the sweet wide body kit? What brand is it? Did it come with the car or did you mount? How much wider wheels can you fit with the wider flares? Sorry for the 20 questions! Great looking car so far.
Re: Honda k24 swap
Dragonist wrote:Vlad wrote:Hello good to see how this build is going. I currently have one about 60% done was stuck on front cross member but some solutions are in the works
Any details you can share on your build? Also how did you mount the K series to the torque tube?
Hey sorry about the delay. I'm very busy with home remodeling, but other than the engine swap the stock 944 drive tran is going to bolt up to the k24 via a Adapter plate to fit between the two. Clutch Master's set me up with a custom fly wheel and throw out bearing along with a hefty clutch disk to hold up some abuse.
Vlad- Posts : 7
Re: Honda k24 swap
Hey buddy, no the K-miata oil pan is totally different and won't work, two options. Cut the cross member or use a dry sump set up. I'm going with the cross member and relocating the rack. I'm still working on it but unfortunately I have to attend to some home projects that need attention so I'll be leaving the project on ice for the next few months. Check back on my build and if you have IG follow me @vladybuildsColibri Green wrote:Hello from Australia,
Vlad- Posts : 7
Re: Honda k24 swap
Has anyone gotten ahead with a k24swaped 944? I had to pause to take care of some necessary house work. Someone tried to purchase a adapter plate from me but it felt like a Fraud case.
Vlad- Posts : 7
Re: Honda k24 swap
89EFhatch wrote:Sorry for disappearing.
I am starting to work on the project again. I was busy working on building a new workshop and getting that functional.
To answer one of the questions, I will be running an AEM Infinity and custom wiring harness.
Hopefully some more updates to come soon
Cant wait to hear more updates! this is an ideal swap, in my opinion. 5cylinder cars sound the best but it's hard to beat the power-weight ratio of the k motors, especially with a little boost.
ChrisCO- Posts : 4
Re: Honda k24 swap
Well put, ChrisCO.
This is indeed a thread where we wait with baited breath. I suspect the clash of the k24 oil pump and front cross member / steering rack why we don’t see more k swaps on the 924/944/968 platform.
Regards moving the rack forward by 4 inches -
I was curious about what effect that might have on the steering and dynamics. Such as Ackermann and bump steer. Interested in any chassis guru’s thoughts. I went back and looked at MWR’s 1.8t subframe and it might be an optical illusion but it seems like they might have moved the rack forward a smidge. Maybe negligible (if at all).
Regarding dry sump-
I was looking into the various dry sump pans, and many have outlets or ridges that could similarly clash with the front rack / crossmember, or inhibit a nice low mounting. Then I stumbled upon this thread where a k24 was being mounted quite far back in an MX5 because of an s2000 gearbox. Old mate designed and machined a sump that looks like it would be perfect for the 924/944/968 application, with two outlets at the rear only-
Anyway, food for thought, as you say the power to weight ratio seems so appealing for a k swap, on paper. Particularly if weight is a key consideration (eg 924). But it also makes you appreciate the elegant engineering of Boost Brothers’ 07k kit. Fascinating comparison. Someone capable (and crazy) just needs to commit and lead the way. Go Vlad and 89EFHatch!
Regarding dry sump-
ChrisCO likes this post
Re: Honda k24 swap
Have we had any updates on this in the last year? I’m just about to pull the trigger and accumulate parts ready for the winter. Engine is ready to go
lukedanwarner@gmail.com- Posts : 1
Re: Honda k24 swap
I have been working on the project still. Finished the wiring, cooling system, stainless exhaust, engine mounts. Im working on the brake master cylinder now. I'll try to remember to take more pictures and post more. Here's a couple pictures for now
Thanks for looking
Thanks for looking
89EFhatch- Posts : 16
Re: Honda k24 swap
Nice one 89EFhatch!
Nice flex of your welding skills, on that inlet manifold. Can’t wait to see what you did with the exhaust.
How did you go with the sump/subframe? Any pics? I can’t quite make it out in the pic.
Re: Honda k24 swap
I upgraded to a K20 oil pump but the sump was just notched a little. The subframe was modified to clear the sump. I didn't many pictures but I found one. I'll find a picture of the exhaust
Colibri Green likes this post
Re: Honda k24 swap
I have been working on the project some and was able to make it move under it's own power today!
Here's a short video
Re: Honda k24 swap
Top work! Impressively chunky fabrication on the subframe.
How did the the steering go with it moved so far forward? Extend the steering shaft I take it? Any weird steering issues in your initial test drive or is it behaving itself?
Re: Honda k24 swap
Initially it felt okay. I just made the steering shaft yesterday, it ended up being 1.8" longer. I need to re bleed the brakes and then I'll take it on the road a little and see how it really feels.
Also I haven't adjusted the alignment at all so I'm sure it's toed in a little from shifting the rack forward
Re: Honda k24 swap
I was able to bleed the brakes, mount the exhaust, and do a quick alignment (it had 1" of toe out after moving the rack the forward). Then take it out for a quick spin.
Here is a short video of the first trip on the road.
Its a little smoky but that is gas that is years old at this point.
Re: Honda k24 swap
Hey 89EFhatch,
Amazing to see the videos, incredible achievement!
Have you had the chance to get some miles on it? Would love to hear any insights.
Re: Honda k24 swap
Colibri Green wrote:Hey 89EFhatch,
I registered it a week or 2 ago and the weather has not been great since. As soon as the weather gets better here in upstate New York I'll be putting some miles on it.
Page 2 of 2 • 1, 2
Page 2 of 2
