Honda k24 swap
+15
Colibri Green
swift5508
Vlad
Dragonist
ajulka123
ptkorson
Dominicandude
Stuey86porsche944
s2k944alan
SilverLined
jso944
87944turbo
slow_944S
89EFhatch
19 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Honda k24 swap
Hi everyone,
I'm relatively new here and thought I'd share my current project with you all.
As the title states I'm swapping a Honda K24 into a 1987 944s. I've pretty much just been mocking an engine in there and figuring out what I need to do from there.
I originally want to do a Honda J35 v6 swap but that was going to require more firewall and hood modification than I wanted to do at this time.
The first picture is of the J35 sitting in there.
And this is the K24 mocked up. The bellhousing adapter will start next week with any luck.
Thanks for looking
Thanks for looking
89EFhatch- Posts : 16
Dragonist and Vlad like this post
Re: Honda k24 swap
Are you planning on staying naturally aspirated? Is that the same engine as an Acura TSX? Good luck with the swap.
slow_944S- Posts : 2
Re: Honda k24 swap
That's a cool project! Have been following a few of these swaps in Civics, seem like really capable engines. See that it sets pretty high. Is it possible to tilt it like the factory did for the Porsche 4 cylinder? Also curious about your brake booster. Did you just remove it for test fitting, or will you have to come up with another solution for power brakes with this engine?
87944turbo- Posts : 76
Re: Honda k24 swap
I was thinking a K-swap would be perfect and am interested to see how this goes. I'm interested to see what kind of clearance the hood has too. 200+ hp naturally aspirated is definitely nice with the possibility of much more with forced induction.
jso944- Posts : 3
Re: Honda k24 swap
Thanks everyone. I removed the booster while test fitting the V6. I hope to retain the factory booster and brakes with the K24.
Hood clearance will be tight but I think its going to clear with a work. The Honda engine leans 15degrees in the same direction as the factory Porsche engine does so that helps. Also people swap these engines into Miatas and "chamfer" the front edge of the valve cover for clearance.
I started making the bellhousing adapter yesterday. Started with half of an Acura RSX manual transmission. Hopefully more progress soon
Thanks for looking
Thanks for looking
Angelspi99 and SilverLined like this post
Re: Honda k24 swap
Great project! So is it about an inch and a half higher than the Porsche mill? Any idea on the weight difference?
Came over from another forum just to post up in here, as I was struck with this idea when thinking about possible swaps. 250 NA HP would be a blast in a 944, and these motors are ubiquitous.
SilverLined- Posts : 1
Re: Honda k24 swap
SilverLined wrote:Great project! So is it about an inch and a half higher than the Porsche mill? Any idea on the weight difference?
The 944 didn't have an engine in it when I got it so I don't know about the height difference. I believe the k24 weighs about 275lbs.
Dragonist likes this post
Re: Honda k24 swap
I designed a little adapter plate the past few days and cut a mock up plate. So far it's looking good. I'll think about it over the weekend and cut a real one next week. Here's a couple pictures to check it out.
Thanks for looking!
Thanks for looking!
Re: Honda k24 swap
What is the depth of the tsx bellhousing?
Re: Honda k24 swap
spence wrote:What is the depth of the tsx bellhousing?
It's pretty close to 5.5" and I measured the 944 bellhousing at a little over 6". So my adapter will be made from .5" plate. This should make for good pilot bearing/bushing engagement. We will see.
Hopefully the engine, bellhousing and clutch will all be sitting in the engine bay bolted together next weekend.
Thanks for checking it out
Re: Honda k24 swap
I always wondered what a f20c or f22c engine would be like in a 944. K24 will be nice too though... Goodluck!
Re: Honda k24 swap
spence wrote:I always wondered what a f20c or f22c engine would be like in a 944. K24 will be nice too though... Goodluck!
Thank you! I hope it all works out.
Re: Honda k24 swap
I was able to get the flywheel and clutch mounted. And then the bellhousing and adapter plate. So far everything is looking pretty good. I had to clearance the "transmission tunnel" a little for the Acura slave cylinder. But it's bolted in there. I removed the oil pan and oil pump. The new oil pump is on the way. Then I'll start cross member and oil pan modifying. The stock oil pumps are huge so I'm pumping the much smaller RSX type S unit in. And here are a few pictures of the progress so far
Thanks for looking
Thanks for looking
Re: Honda k24 swap
Any updates on this? What are you planning for the oil pan, something like the Touge Factory unit? I'm pretty interested as this seems like a good swap.
jso944- Posts : 3
type_c likes this post
Re: Honda k24 swap
I am going to do a K24 in my 83 944. I have the K24 and am starting to rebuild. Please keep updating as i would love to see how you handle things! Any chance I could buy an adapter plate off you?
s2k944alan- Posts : 1
Re: Honda k24 swap
What clutch are you using? And what’s your plan for the wiring? I was looking into doing this swap in my 86 944 and just need to sort out the details before diving in.
Stuey86porsche944- Posts : 1
Re: Honda k24 swap
Any updates on this project? Was it ever completed? Or did you run into show stopping obstacles? Curious before I either pull a this K out for a swap or just sell the Honda and finish the LS to swap in.
Dominicandude- Posts : 1
Re: Honda k24 swap
I would love to know as well. Just saw a k swapped Ferrari and I now have ideas...
ptkorson- Posts : 5
Re: Honda k24 swap
There’s a k group on Facebook with a running turbo k 968.
Any update on this project and does anyone have anymore info?
ajulka123- Posts : 5
Dragonist and lukedanwarner@gmail.com like this post
Re: Honda k24 swap
Sorry for disappearing.
I am starting to work on the project again. I was busy working on building a new workshop and getting that functional.
To answer one of the questions, I will be running an AEM Infinity and custom wiring harness.
Hopefully some more updates to come soon
ChrisCO and Dragonist like this post
Re: Honda k24 swap
89EFhatch wrote:Sorry for disappearing.
Good luck with the project. I know how time consuming that can be. The adapter you made is that the final product?
Dragonist- Posts : 3
Re: Honda k24 swap
What are you using for clutch and flywheel set up?
944 /k24
Hello good to see how this build is going. I currently have one about 60% done was stuck on front cross member but some solutions are in the works. Any with questions feel free.
Vlad- Posts : 7
Re: Honda k24 swap
Vlad wrote:Hello good to see how this build is going. I currently have one about 60% done was stuck on front cross member but some solutions are in the works
Any details you can share on your build? Also how did you mount the K series to the torque tube?
Page 1 of 2 • 1, 2
Page 1 of 2
» Turbo Transaxle wanted
