» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
Has anyone swapped a honda engine?
Post  Jimmyac28 on Sun Jun 05, 2016 9:58 am
I was thinking about a 4 cilynder engine swap that would have lots of potential and be reliable. I was wondering if anyone tried to swap in an f20c engine from an s2000 or maybe a k20A from an RSX? This engines are reliable and have tons of aftermarket support, also I think the NA transaxle would be able to handle their power good since this engines are low on torque unlike with a V8 swap I would not have to get a new transmission to handle the power and torque.
Jimmyac28
Re: Has anyone swapped a honda engine?
Post  sharkey on Sun Jun 05, 2016 12:30 pm
i dont think anyone has. one thing to keep in mind that the honda f20 is very tall. it does have the fact its mounted on a bit of an angle in the s2k working in your favor. you will likely have problems with the intake manifold interfering with the master cylinder. add in a custom bellhousing, motor mounts, oil pan, etc.
i have a chevy ecotec 4 cylinder in my 944, it was no piece of cake to get in thats for sure, i think an ls swap from scratch would have been easier.
Post  Jimmyac28 on Sun Jun 05, 2016 6:20 pm
I guess the V8 swap would be more cost efective then? How hard was your ecotec swap?
Jimmyac28
Post  Jimmyac28 on Sun Jun 05, 2016 6:25 pm
If the intake manifold is on the way, I can always go with an ITB setup to fix that problem
Jimmyac28
Post  sharkey on Sun Jun 05, 2016 7:19 pm
the other option would be to run a floor mounted pedal assembly from tilton or wilwood. more than one way to solve that potential problem.
really the feasability of it depends on how much work you can do yourself, and if you have the contacts to farm out the work you arent able to do. the way i look at it is go into the project knowing nothing is going to be easy, and everything needs to be modified to make anything fit. as long as your ok to cut up pretty much anything its completely feasable.
oh, and plan on having a hole in the hood, or a scoop.
Post  racertomtom on Sun Jun 05, 2016 10:06 pm
sharkey wrote: as long as your ok to cut up pretty much anything its completely feasable.
LOL, that’s exactly my philosophy. Twisted Evil
racertomtom
