» 4.8 Ls beast!
Convert 944 LT1 Swap to LS Swap EmptyYesterday at 5:07 pm by yamamtx
» RX7 oil cooler installation
Convert 944 LT1 Swap to LS Swap EmptyYesterday at 8:24 am by gwistrup
» PORSCHE 944 5th-0.68 , other gearbox parts GOT all you need!
Convert 944 LT1 Swap to LS Swap EmptyMon Apr 06, 2020 12:51 pm by Martynas
» 86 Porsche 944T LS1 swap begins
Convert 944 LT1 Swap to LS Swap EmptySun Apr 05, 2020 10:15 pm by smkn951
» Set of Wilwood big brake adapters
Convert 944 LT1 Swap to LS Swap EmptySat Apr 04, 2020 5:35 pm by scryfst
» RX7 Caliper swap adapters
Convert 944 LT1 Swap to LS Swap EmptySat Apr 04, 2020 5:21 pm by scryfst
» Ford Windsor engine swap
Convert 944 LT1 Swap to LS Swap EmptySat Apr 04, 2020 12:00 pm by haroldk
» C5 Transmission and TT?
Convert 944 LT1 Swap to LS Swap EmptyThu Apr 02, 2020 2:25 pm by spence
» looking for 944 v8 conversion manual
Convert 944 LT1 Swap to LS Swap EmptyWed Apr 01, 2020 3:28 am by spence
» 944 S2 - LS3 & T56 Conversion
Convert 944 LT1 Swap to LS Swap EmptyTue Mar 31, 2020 11:09 am by Slpr948
April 2020
6789101112
13141516171819
20212223242526
27282930
Convert 944 LT1 Swap to LS Swap Empty Convert 944 LT1 Swap to LS Swap
Post  Frederiksen on Sun Mar 01, 2020 8:34 am
I own a car with a LT1 swap but I want to change the engine to a LS. I've used a Renegade Hybrids kit for the LT1 swap. I also have an exhaust, headers, and an intake on the LT1. Does anyone know what parts from the kit and from my old setup are compatible to use for my LS swap?
Frederiksen
Frederiksen
Convert 944 LT1 Swap to LS Swap Empty Re: Convert 944 LT1 Swap to LS Swap
Post  Hotrodz of Dallas on Tue Mar 17, 2020 3:57 pm
Depending on what bell housing you used, that may likely be the only part that will work on the LS. Motor mounts, exhaust manifolds/headers, clutch and flywheel, etc are all different. Plus it will be a different wire harness and ecu for the LS.
Hotrodz of Dallas
Hotrodz of Dallas
