V8 Swap Project Car Swap Out
+2
Eric00433
DirtRocket
6 posters
Unfortunately its time for me to move on. I started a V8 swap after my inline 4 blew. I have since moved and started a new job. I no longer have a lift or an actual garage to work on the car in and as such I must sell. Everything was purchased last summer and none of it has been actually used, very few parts ever even made it onto the car.
The car has one baseball sized rust hole where the battery sits and some rust starting to show underneath. When I had my lift I did not see anything other than some slight surface rust so this has gotten worse over the winter despite not seeing any salt. The wiring has been mostly gutted from the engine bay and the plan was to remove the pop up headlights so the mechanism to open them has been removed. The exterior was painted by a PO at least 5 years ago according to the man I bought it from. Its not horrible, however you can definitely tell in some spots where the prep was poor. The car was pretty cheap and it was only meant to be a track car when I started.
The engine is a 5.3 iron block from a 2003 Chevy 1500 with approximately 100k miles. Make me an offer if you want it. It is basically a stripped long block. The clutch/pp/flywheel and the oil pan are on the engine.
ALL SWAP PARTS AND COILS HAVE BEEN SOLD. Someone make me an offer on the rest of the vehicle I want it gone. Will consider parting the rest of the car out if someone wants larger parts off it.
I don't have any photos of the whole car. It is currently jammed in a tiny garage so getting photos is a pain. If anyone is actually interested let me know specifically what you're interested in and I'll send you photos. Can call or text 570 317 3464 as well. Located in Bloomsburg, PA.
DirtRocket- Posts : 6
Re: V8 Swap Project Car Swap Out
I would be interested in taking some of the parts off your hands. I am in the middle of mine and could use a handful of items you have that should be easy to ship. Let me know if you are good with parting out and I’ll text you in the morning. Thanks.
Eric00433- Posts : 8
I am willing to part it out. Let me know what you need and I'll see what I can do. I would like to sell the conversion kit as a whole if I can. I also have custom headers from TPC I forgot to mention.
I'm interested in the following parts.
C5 Corvette Bell Housing - New
C5 Bell Housing dust cover
C5 Corvette Bell housing Adapter Plate
Hydraulic Slave Throw Out Bearing
With Hoses, Fittings and Bleeder Valve
TPC Clutch Kit
TPC Clutch, Steel Flywheel, Stock Pressure Plate, ARP Bolts for Flywheel and Pressure Plate
LS Engine Pilot Bearing Adapter
LS Engine Conversion Motor Mount Uprights
Solid Motor Mount Bushings
1/2 Spacers
TPC Turbo Style Radiator
Includes 944 to LS hoses, 187 degree Thermostat, straight lower hose outlet
TPC 944 Turbo Fan shroud kit
Heater Control Valve and Hoses
VSS Kit With Sensor
Custom Oil Pan w/ Internal Baffles
I'm in the process of building an ls1 with 243 heads and upgraded cam.
do you happen to have the engine management too and harness?
BTW I have an 86 944t. currently my DD.
please let me know how much shipped to 79938?
thank you
TPC Clutch Kit
1/2 Spacers
VSS Kit With Sensor
thank you
smkn951- Posts : 60
where abouts are you located?
MotoRider42HC- Posts : 116
MotoRider42HC wrote:where abouts are you located?
Bloomsburg, PA
i sent you a message for the suspension and TPC radiator msg me back with pricing !
matt889- Posts : 214
Suspension and TPC parts have been sold. Car is still available. If anyone wants a 1983 Porsche 944 shell for cheap make me an offer.
$750 for the car someone come get this thing!
I have some spare quarters sitting around. The wife may make me sleep the couch for a bit but let me know if you just need to unload the thing.
ptkorson- Posts : 5
