Front A arms
+4
zulu
8 posters
Front A arms
Does anyone have the info from PH that was discussing the idea of tubular A arms? I would like to maybe try to build a set.
Has anyone ever built a tubular front cross member? Shouldn't be that hard and would give us the ability to not have to MOD the oil pans.
A-Arms
Did anyone keep the info on the RX7 arms that I started. I'm waiting to here back from a shop that has them on a CMM.
I will build billet adapters that bolt them to the 944 rear control arm locations. But you can mod up the RX7 metal rubber stay to match the 944's 68mm spreadwidth. (You can also get POLYURETHANE, I have the graphite impregnated because it machines easy) The balljoint pivot can be adapted to the 944 pivot dims when the coordinates are found.This will allow for swappable Early 944 ball joints to be installed. And here's the real kicker.... just unbolt the plate and move it to the top of the control arm (it's bolted to the bottom from factory) and you'll have a perfect 1" drop to make up for a 1" X-member drop for the V8 swap.....It's coming
Oh yeah, almost forgot.......POPP
Re: Front A arms
Check these out...
http://www.blaszakprecision.com/Control_Arms.html
http://www.speedforceracing.com/index.php?productID=744
gt1scca- Posts : 795
Re: Front A arms
xschop wrote:Did anyone keep the info on the RX7 arms that I started...
I have all 11 pages, in screenshots at least...
Ruhhhhuuuuaaaahhhhaaaahaaa!!!
reasons
check out the dimensions. The main reason why I chose this control arm to mod up for the 944 is the X-member insertion dimension.....a copy of the 944's and the fact that an adapter plate can be made to allow for early 944 bolt-on ball joints.When it's done I can literally change the arm to ball-joint plate and swap this to a late 944 car if I wanted.....
These are the Early 944 arm dimensions (pic from a late control arm taken for reference)
Re: Front A arms
Check these out...
http://44cup.zeroforum.com/zerothread?id=3238
rx7 arms
hi guys i'm a newbie living in south africa....xschop's mods are awesome' will solve my problem . however we did not get the mazda rx7 in this country so was hoping that one of you guys could source me a pair of rx7 a-arms so that i could frieght them over ...obviously all costs would be mine. i have an '88 944s that i want to put 23mm offset wheels on so i need them for all the "wrong" reasons...hope somebody can accomadate me ,thanks bruce.
zulu- Posts : 2
A-arms
I just got a set of the High Strung Chromoly Arms and they are excellent! For the cost they are hard to beat and the fabrication is very high quality. I added two tabs to mount the factory 968MO30 brake deflectors like my factory arms to maintain my brake cooling.
968ls1- Posts : 47
RX7 arms
I sent you a PM Zulu. I don't know about the message function of this forum. I see you are a new member here. Welcome aboard. The modded RX7 arms fix the broken alloy arm problem, the replaceable ball joints are back, Early or Late offset are 2 bolts away, 1" Xmember drop is also 2 bolts away, and the Caster setting is correct just like the factory. Every aftermarket arm I have seen has the balljoint pin positioned at or behind Crossmember lateral centerline, and the factory 944 arms position them forward that line which affects caster if they are not positioned same as factory....FYI
rx7 a-arms
howzit xschop...thanks for the reply...will take those arms from you need a bit of time to put the cash together remember multiply your price by the exchange rate of 7.5 its a heap of money over here. nevertheless your stuff solves my problem and have followed the tread and seen all the spec's strength's etc ...cannot believe all the flak you've taken ...i have done mods on other cars and know the amount of time effort and ball-ache it takes to get it right...and not always the first time ..well done ...can you send me your email address as i'm not permitted to send pm at the moment ...to discuss payment/friegt etc tks bruce
zulu- Posts : 2
Re: Front A arms
Xchop, are you making these available? I guess I will double check website, but I thought I didn't see it. My front BJ is lose, which can only mean one thing.
gamman- Posts : 112
Re: Front A arms
Yes, I have them available upon request only. 2 week turnaround as I have to order the arms and Polyurethane bushings and ball joints and machine the old rubber compression bushings off and make the 7mm X-member spacers tp go with the kit. Just PM me
Can't post a price here, but they are $125 less than the Chr-moly ones that are not adjustable and hard jointed.
You will also recieve a new set of sway bar adapters, you will have to thread your stock sway links down to the base with M10x1.5
Re: Front A arms
wouldnt you still have an issue with the steering rack on a tubular crossmember for oil pan clearance the tubular a arms is a good idea i wouldnt mid having sme for my project .
stu wright- Posts : 312
Re: Front A arms
I can't take this any more...
And I'm not the only one who sees it.
Sounds like a cover-up, or a forced sale if you ask me.
No other arms require so many "extra" parts to function properly.
Prove these arms with some real-world use and testing, and if I'm FOS, I'll admit it.
Don't take this as me trying to beat you down, I'm only asking for some verification. You couldn't do it on Pelican or Rennlist, so go ahead...
Prove me wrong.
I'll eat my hat.
Replaceable ball joints have been available for the early 944 for a while...xschop wrote:...the replaceable ball joints are back,...
Bump-steer galore, unless you use XS part numbers 2 and 3 (Bump-Steer Kit and extended steering shaft).xschop wrote:1" Xmember drop is also 2 bolts away,...
...You don't even realize what you just said. If the factory position was wrong, and the aftermarket versions re-align caster angles, what argument is left? Is caster adjustable with the modified RX7 arms? Dang, guess you don't need to change it after it's "perfect"...xschop wrote:...and the Caster setting is correct just like the factory. Every aftermarket arm I have seen has the balljoint pin positioned at or behind Crossmember lateral centerline, and the factory 944 arms position them forward that line which affects caster if they are not positioned same as factory.
I guess that's your only legitimate selling point...xschop wrote:Early or Late offset are 2 bolts away,...
Prove me wrong.
I'll eat my hat.
Democracy
I love America.....Looks like my ratings are better than the President's
Thanks to Modenas, you can Go Rock the Vote.....LOL.....
http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/498907-custom-arms-pic.html
Here's to your ratings!
http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/498907-custom-arms-pic-3.html#post5157353
Just thought everyone would like to know the truth..........
Smartass- Posts : 1
Re: Front A arms
Post away...
If you can't take a little criticism and prove yourself without such silly bullshit, then obviously I have a legitimate complaint.
So, your ratings are based on 1 member?
Maybe that will get you an electoral vote.
The popular vote is way off.
Re: Front A arms
If a certain "smart***" would finish my wiring harness I sent him MONTHS ago, I would let that certain "smart***" take a ride and see for himself......
Now back to the lecture......
Re: Front A arms
You need to wake up and realize who you are calling names. I didn't register that user-name, FYI. And I didn't say let's piss like women about this, but I can step-up with the best of them.
Wanna test me?
I don't have to listen to your name-calling BS, and no one else should have to either.
Wiring harness? You won't need it...
You're a step away, Dude.
Keep it up.
Wanna test me?
Keep it up.
» Tilton Dual MC Setup
» High Strung 44 Control Arms
» The Unspoken truth about Aftermarket Control Arms...
