Yesterday at 8:00 pm by Luke714
Yesterday at 12:23 pm by chrenan
» What dipstick??
Sat Jun 23, 2018 4:54 pm by chrenan
Sat Jun 23, 2018 8:28 am by rawr
Fri Jun 22, 2018 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
June 2018
Front A arms
Front A arms
Post  Admin on Thu Jun 11, 2009 12:39 pm
Does anyone have the info from PH that was discussing the idea of tubular A arms? I would like to maybe try to build a set.
Has anyone ever built a tubular front cross member? Shouldn't be that hard and would give us the ability to not have to MOD the oil pans.
A-Arms
Post  xschop on Thu Jun 11, 2009 12:53 pm
Did anyone keep the info on the RX7 arms that I started. I'm waiting to here back from a shop that has them on a CMM.
I will build billet adapters that bolt them to the 944 rear control arm locations. But you can mod up the RX7 metal rubber stay to match the 944's 68mm spreadwidth. (You can also get POLYURETHANE, I have the graphite impregnated because it machines easy) The balljoint pivot can be adapted to the 944 pivot dims when the coordinates are found.This will allow for swappable Early 944 ball joints to be installed. And here's the real kicker.... just unbolt the plate and move it to the top of the control arm (it's bolted to the bottom from factory) and you'll have a perfect 1" drop to make up for a 1" X-member drop for the V8 swap.....It's coming
Oh yeah, almost forgot.......POPP
Re: Front A arms
Post  gt1scca on Thu Jun 11, 2009 1:10 pm
Check these out...
http://www.blaszakprecision.com/Control_Arms.html
http://www.speedforceracing.com/index.php?productID=744
Re: Front A arms
Post  gt1scca on Thu Jun 11, 2009 1:15 pm
xschop wrote:Did anyone keep the info on the RX7 arms that I started...
I have all 11 pages, in screenshots at least...
Ruhhhhuuuuaaaahhhhaaaahaaa!!!
reasons
Post  xschop on Thu Jun 11, 2009 1:17 pm
check out the dimensions. The main reason why I chose this control arm to mod up for the 944 is the X-member insertion dimension.....a copy of the 944's and the fact that an adapter plate can be made to allow for early 944 bolt-on ball joints.When it's done I can literally change the arm to ball-joint plate and swap this to a late 944 car if I wanted.....
These are the Early 944 arm dimensions (pic from a late control arm taken for reference)
Re: Front A arms
Post  gt1scca on Sat Jun 20, 2009 3:03 am
Check these out...
http://44cup.zeroforum.com/zerothread?id=3238
rx7 arms
Post  zulu on Sat Jan 23, 2010 12:33 am
hi guys i'm a newbie living in south africa....xschop's mods are awesome' will solve my problem . however we did not get the mazda rx7 in this country so was hoping that one of you guys could source me a pair of rx7 a-arms so that i could frieght them over ...obviously all costs would be mine. i have an '88 944s that i want to put 23mm offset wheels on so i need them for all the "wrong" reasons...hope somebody can accomadate me ,thanks bruce.
zulu
A-arms
Post  968ls1 on Mon Jan 25, 2010 10:43 am
I just got a set of the High Strung Chromoly Arms and they are excellent! For the cost they are hard to beat and the fabrication is very high quality. I added two tabs to mount the factory 968MO30 brake deflectors like my factory arms to maintain my brake cooling.
968ls1
RX7 arms
Post  xschop on Mon Jan 25, 2010 12:35 pm
I sent you a PM Zulu. I don't know about the message function of this forum. I see you are a new member here. Welcome aboard. The modded RX7 arms fix the broken alloy arm problem, the replaceable ball joints are back, Early or Late offset are 2 bolts away, 1" Xmember drop is also 2 bolts away, and the Caster setting is correct just like the factory. Every aftermarket arm I have seen has the balljoint pin positioned at or behind Crossmember lateral centerline, and the factory 944 arms position them forward that line which affects caster if they are not positioned same as factory....FYI
rx7 a-arms
Post  zulu on Tue Jan 26, 2010 2:51 am
howzit xschop...thanks for the reply...will take those arms from you need a bit of time to put the cash together remember multiply your price by the exchange rate of 7.5 its a heap of money over here. nevertheless your stuff solves my problem and have followed the tread and seen all the spec's strength's etc ...cannot believe all the flak you've taken ...i have done mods on other cars and know the amount of time effort and ball-ache it takes to get it right...and not always the first time ..well done ...can you send me your email address as i'm not permitted to send pm at the moment ...to discuss payment/friegt etc tks bruce
zulu
Re: Front A arms
Post  gamman on Wed Jan 27, 2010 10:42 am
Xchop, are you making these available? I guess I will double check website, but I thought I didn't see it. My front BJ is lose, which can only mean one thing.
gamman
Re: Front A arms
Post  xschop on Wed Jan 27, 2010 11:54 am
Yes, I have them available upon request only. 2 week turnaround as I have to order the arms and Polyurethane bushings and ball joints and machine the old rubber compression bushings off and make the 7mm X-member spacers tp go with the kit. Just PM me
Can't post a price here, but they are $125 less than the Chr-moly ones that are not adjustable and hard jointed.
You will also recieve a new set of sway bar adapters, you will have to thread your stock sway links down to the base with M10x1.5
Re: Front A arms
Post  stuart f. wright on Wed Jan 27, 2010 6:23 pm
wouldnt you still have an issue with the steering rack on a tubular crossmember for oil pan clearance the tubular a arms is a good idea i wouldnt mid having sme for my project .
stuart f. wright
Re: Front A arms
Post  gt1scca on Sat Jan 30, 2010 11:18 pm
I can't take this any more...
And I'm not the only one who sees it.
xschop wrote:...the replaceable ball joints are back,...
Replaceable ball joints have been available for the early 944 for a while...
xschop wrote:1" Xmember drop is also 2 bolts away,...
Bump-steer galore, unless you use XS part numbers 2 and 3 (Bump-Steer Kit and extended steering shaft).
Sounds like a cover-up, or a forced sale if you ask me.
No other arms require so many "extra" parts to function properly.
xschop wrote:...and the Caster setting is correct just like the factory. Every aftermarket arm I have seen has the balljoint pin positioned at or behind Crossmember lateral centerline, and the factory 944 arms position them forward that line which affects caster if they are not positioned same as factory.
Razz ...You don't even realize what you just said. If the factory position was wrong, and the aftermarket versions re-align caster angles, what argument is left? Is caster adjustable with the modified RX7 arms? Dang, guess you don't need to change it after it's "perfect"...
Rolling Eyes
xschop wrote:Early or Late offset are 2 bolts away,...
I guess that's your only legitimate selling point...
Prove these arms with some real-world use and testing, and if I'm FOS, I'll admit it.
Don't take this as me trying to beat you down, I'm only asking for some verification. You couldn't do it on Pelican or Rennlist, so go ahead...
Prove me wrong.
I'll eat my hat.
Democracy
Post  xschop on Sun Jan 31, 2010 10:10 am
I love America.....Looks like my ratings are better than the President's
Thanks to Modenas, you can Go Rock the Vote.....LOL.....
http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/498907-custom-arms-pic.html
Here's to your ratings!
Post  Smartass on Sun Jan 31, 2010 10:44 am
http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/498907-custom-arms-pic-3.html#post5157353
Just thought everyone would like to know the truth..........
Smartass
Re: Front A arms
Post  gt1scca on Sun Jan 31, 2010 11:02 am
Post away...
If you can't take a little criticism and prove yourself without such silly bullshit, then obviously I have a legitimate complaint.
So, your ratings are based on 1 member?
Maybe that will get you an electoral vote.
The popular vote is way off.
Razz
Re: Front A arms
Post  xschop on Sun Jan 31, 2010 11:03 am
If a certain "smart***" would finish my wiring harness I sent him MONTHS ago, I would let that certain "smart***" take a ride and see for himself......
Now back to the lecture......
Re: Front A arms
Post  gt1scca on Sun Jan 31, 2010 11:12 am
You need to wake up and realize who you are calling names. I didn't register that user-name, FYI. And I didn't say let's piss like women about this, but I can step-up with the best of them.
Wanna test me?
I don't have to listen to your name-calling BS, and no one else should have to either.
Wiring harness? You won't need it...
You're a step away, Dude.
Keep it up.
Re: Front A arms
