Mon Jul 08, 2013 10:56 pm by Admin
Today at 7:13 pm by superman22x
Today at 2:40 am by VA944LS1
Yesterday at 9:47 pm by kevin924kevin
» New 944 widebody & aero
Yesterday at 12:56 am by scryfst
Thu Feb 22, 2018 6:23 pm by Murrdog9000
Thu Feb 22, 2018 1:41 am by 962porsche
Wed Feb 21, 2018 5:58 am by 948
Tue Feb 20, 2018 7:51 pm by acorad
» Oil Pan question
Tue Feb 20, 2018 4:41 pm by Rothaus
» 83' Porsche 944 LM7 Build
Mon Feb 19, 2018 8:39 pm by Jchard944
Early Control Arms on a late car
Post  Red944ls1 on Tue May 23, 2017 7:15 pm
Hi all. I have a 1990 S2 that has worn control arms. I would like to put my rebuilt early arms on the S2...will they fit?
Red944ls1
Re: Early Control Arms on a late car
Post  sharkey on Tue May 23, 2017 8:03 pm
87+ cars have a wider suspension width, so the control arms are longer. i seem to remember seeing something about putting steel arms on a late car, but im not sure whats all needs to be done to make it happen.
Post  944_GASM on Tue May 23, 2017 9:29 pm
sharkey wrote:87+ cars have a wider suspension width, so the control arms are longer. i seem to remember seeing something about putting steel arms on a late car, but im not sure whats all needs to be done to make it happen.
I believe you would need to swap the complete front suspension off an early car (spindles, control arms, tie rod ends, and struts) to make it work.
944_GASM
Post  Red944ls1 on Tue May 23, 2017 10:03 pm
What I question however, is currently the set up is a 1984 - I changes the hubs and shocks to 1987 but the control arms are the same 1984.
The question I have is if we take the control arms that are from the 84 and place them on my 1990 s2 will they fit.
Red944ls1
Post  pormgb on Wed May 24, 2017 6:43 am
I am running a combination of late spindles, struts and hubs with early tubular A arms (SFR Tubular). With this configuration that is like yours if you use early A arms, you will end up with not enough room to get proper camber adjustment due to shorter early A arms. To fix this issue, I installed camber plates that provide the extra travel to dial in proper caster and camber.
I went this path so I could use a late model TT big brake kit with ABS spindles, I also wanted to keep my 1986 tubular SFR A arms.
Late model struts won't bolt up to early spindles unless you modify the strut spindle mount (there is a write up on this forum). As previously mentioned, you would have to change your complete front suspension to an early setup and this will also change your front offset, you will need spacers with late model wheels.
If you want stronger A arms, get a pair of late model aftermarket tubular A arms. You could also rebuild your current A arms if the aluminum around the ball joint is not damaged, Rennbay sells the kits.
pormgb
