968cs ls swap
+2
RestomodCorvettes
Ryding
6 posters
968cs ls swap
Hello.
Im located in stockholm/sweden. Bought a 968cs a couple of years ago, but always felt that the engine doesnt match the chassi.
Decided to do something about it.
https://www.dropbox.com/s/68mmmihw9ffvg2b/IMG_9522.jpg?dl=0
https://www.dropbox.com/s/3x3op1de7ohqdmr/IMG_9558.jpg?dl=0
Last edited by 944-LT1 on Mon Jan 15, 2018 1:37 pm; edited 2 times in total (Reason for editing : pics not showing)
Ryding- Posts : 5
Re: 968cs ls swap
Hi looks great I am in Spain Just started to get my bits together, have bought a 1994 968 couple and a salvage 2008 Corvette z06 , just arranging for them to be shipped , then the fun will begin, what kit did you use on yours
Marbella968ls- Posts : 9
6 speed trans
how is the gearing with this motor? I have a 6.0 gto motor I am going to be swaping into my 968, but I was told the gearing was better with the 944 turbo s 5 speed? How is the speed/rpm with the motor/6speed trans?
mdan1- Posts : 8
Re: 968cs ls swap
mdan1 wrote:how is the gearing with this motor? I have a 6.0 gto motor I am going to be swaping into my 968, but I was told the gearing was better with the 944 turbo s 5 speed? How is the speed/rpm with the motor/6speed trans?
Having done the 968 6 speed swaps on 944's with an LS, I can tell you that the 944 gearing is better. The 968 trans has basically the same gearing as an S2 trans, but with one more overdrive gear. The 6th gear then is similar to the turbo's 5th gear. You wind up doing a lot of rapid shifting in the lower gears. There is a company in Texas that re-gears the 968 trans and then it works great. But, not cheap. Only real reason to do the 968 swap is for the added strength to handle more torque and horsepower.
Best alternative, is a turbo trans with the taller .68 5th gear installed. That setup works really well.
I don't remember the rpm/mph numbers for each trans, but the turbo with .68 5th is about 1500 rpm lower than the stock 968 trans at 80 mph
Re: 968cs ls swap
Do you recall the name of the company that regearscthe 968 trans?
Freelancelance- Posts : 1
Re: 968cs ls swap
Freelancelance wrote:Do you recall the name of the company that regearscthe 968 trans?
https://advancedautomotion.com/shop/
