» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
GM 60* V6 swap
GM 60* V6 swap
Post  RacerX on Thu May 08, 2014 9:23 am
Just wondering if anybody has done a 60* GM V6 swap? My thought is it has to be cheaper then the
V8. It's a little more HP but not enough that you would need a big brake kit and the transaxle would be able to handle the extra HP. So, has anybody done this swap yet??
RacerX
Re: GM 60* V6 swap
Post  applebit on Thu May 08, 2014 9:02 pm
My brother installs those in British cars: [You must be registered and logged in to see this link.]
For the money a 5.3 liter ls series engine will go much further Smile
applebit
applebit
http://www.bmcautos.com/
Re: GM 60* V6 swap
Post  RacerX on Thu May 08, 2014 11:31 pm
I hear what your saying, BUT, with that big V8 comes more power and torque. I'll need to add a big brake kit, bigger wheels and tires, and a transaxle from a 944 turbo. If I can drop in a small V6, like the 3.4 60* GM motor, that only makes about 20-40 HP more than the stock 944, I'll be able to forgo all of the above mentioned up-grades. I'm not looking for max power, just a little more power than stock. And the 2 biggest reasons for doing this would be cost and reliability.
RacerX
Re: GM 60* V6 swap
Post  applebit on Fri May 09, 2014 7:09 am
RacerX wrote:I hear what your saying, BUT, with that big V8 comes more power and torque.  I'll need to add a big brake kit, bigger wheels and tires, and a transaxle from a 944 turbo.  If I can drop in a small V6, like the 3.4 60* GM motor, that only makes about 20-40 HP more than the stock 944, I'll be able to forgo all of the above mentioned up-grades.  I'm not looking for max power, just a little more power than stock.  And the 2 biggest reasons for doing this would be cost and reliability.
Well the 60 degree is a pretty good engine, nice compact size, and easy access to parts. The biggest question is will the brake booster still fit with the engine in there? If so then I would think its an inexpensive upgrade. I ran an LS1 in my 924 with 255's out the back originally and it worked; of course I upgraded the brakes to 944 NA brakes at the time, but had a lack of a brake booster: So it is possible, just not ideal.
applebit
applebit
Re: GM 60* V6 swap
Post  acorad on Fri May 09, 2014 8:14 am
What kind of car do you have? Is it a daily driver? Track car?
Andy
Re: GM 60* V6 swap
Post  applebit on Fri May 09, 2014 8:22 am
Andy
Daily. It has been redone of course and is going through a brake upgrade as we speak, so your point of keeping cost low is valid. You can get a very modest 300 hp 5.3 liter in your car for the same amount of money as the 60 degree and have a greater potential for future upgrades. That being said, the 5.3 that I talk about is slightly heavier then your RWD 60 degree iron block aluminum head configuration. This is my conversion:
applebit
applebit
Re: GM 60* V6 swap
Post  RacerX on Fri May 09, 2014 9:55 am
Andy
This one would be a track toy as I already have a dedicated 944 race car.  The race car uses the stock Porsche motor.  I want something with more reliability, engine wise, and a little more power.  If it was cheap to add power and rebuild the stock motor, I'd stick to it.  But it's not.
[You must be registered and logged in to see this image.][You must be registered and logged in to see this image.]" />
RacerX
Re: GM 60* V6 swap
Post  xschop on Fri May 09, 2014 10:32 am
I'm going to build an LFX 60* V6 next.  Very Happy
Re: GM 60* V6 swap
Post  applebit on Fri May 09, 2014 10:55 am
xschop wrote:I'm going to build an LFX 60* V6 next.  Very Happy
Although not as inexpensive as the 3.4 liter, this has FAR more potential! The reason why the 3.4 liter 60* is so popular for the British cars is the limited size of the engine bay Smile
applebit
applebit
GM 3.4 V6
Post  simon123 on Sat May 10, 2014 8:26 am
I have two modified cars, a MGB GT with a crate 3.4 GM V6 and a 944 with LS1.
My MGB has headers, and a Holly 390 and I believe produces about 200 hp.
I would only put this engine in a 944 if I was looking to replace a blown/worn out engine, the end result would be a nice economical daily driver. For real performance I would use the LS1.
simon123
Re: GM 60* V6 swap
