968cs ls swap EmptyToday at 4:14 pm by SpeedRacer11
» Rear coilover suspension setup
968cs ls swap EmptyToday at 3:30 pm by ThomasJoseph315
968cs ls swap EmptyYesterday at 10:12 am by Nath1142
968cs ls swap EmptyMon Apr 22, 2024 7:22 pm by lowform
968cs ls swap EmptyMon Apr 22, 2024 7:12 pm by lowform
968cs ls swap EmptyMon Apr 15, 2024 7:28 pm by JW1970
968cs ls swap EmptyMon Apr 15, 2024 6:59 pm by JW1970
968cs ls swap EmptyMon Apr 15, 2024 9:51 am by Raymond-P
968cs ls swap EmptyFri Apr 12, 2024 3:07 pm by Rob44
968cs ls swap EmptyWed Apr 10, 2024 10:09 pm by LS982
968cs ls swap
+2
RestomodCorvettes
Ryding
6 posters
968cs ls swap Empty 968cs ls swap
Post  Ryding Sun Jan 14, 2018 7:14 am
Hello.
Im located in stockholm/sweden. Bought a 968cs a couple of years ago, but always felt that the engine doesnt match the chassi.
Decided to do something about it.
https://www.dropbox.com/s/68mmmihw9ffvg2b/IMG_9522.jpg?dl=0
https://www.dropbox.com/s/3x3op1de7ohqdmr/IMG_9558.jpg?dl=0
Last edited by 944-LT1 on Mon Jan 15, 2018 1:37 pm; edited 2 times in total (Reason for editing : pics not showing)
Ryding
968cs ls swap Empty Re: 968cs ls swap
Post  RestomodCorvettes Wed Jan 17, 2018 4:38 am
Nice engine compartment!
RestomodCorvettes
Post  Marbella968ls Mon Mar 02, 2020 12:14 pm
Hi looks great I am in Spain Just started to get my bits together, have bought a 1994 968 couple and a salvage 2008 Corvette z06 , just arranging for them to be shipped , then the fun will begin, what kit did you use on yours
Marbella968ls
968cs ls swap Empty 6 speed trans
Post  mdan1 Fri Feb 05, 2021 2:18 pm
how is the gearing with this motor? I have a 6.0 gto motor I am going to be swaping into my 968, but I was told the gearing was better with the 944 turbo s 5 speed? How is the speed/rpm with the motor/6speed trans?
mdan1
Post  Hotrodz of Dallas Fri Feb 05, 2021 3:35 pm
mdan1 wrote:how is the gearing with this motor?  I have a 6.0 gto motor I am going to be swaping into my 968, but I was told the gearing was better with the 944 turbo s 5 speed? How is the speed/rpm with the motor/6speed trans?
Having done the 968 6 speed swaps on 944's with an LS, I can tell you that the 944 gearing is better. The 968 trans has basically the same gearing as an S2 trans, but with one more overdrive gear. The 6th gear then is similar to the turbo's 5th gear. You wind up doing a lot of rapid shifting in the lower gears. There is a company in Texas that re-gears the 968 trans and then it works great. But, not cheap. Only real reason to do the 968 swap is for the added strength to handle more torque and horsepower.
Best alternative, is a turbo trans with the taller .68 5th gear installed. That setup works really well.
I don't remember the rpm/mph numbers for each trans, but the turbo with .68 5th is about 1500 rpm lower than the stock 968 trans at 80 mph
Hotrodz of Dallas
Hotrodz of Dallas
968cs ls swap Empty brake booster?
Post  mdan1 Sun Aug 01, 2021 4:34 pm
what electric brake booster are you using?
mdan1
Post  Freelancelance Tue Dec 07, 2021 6:27 am
Do you recall the name of the company that regearscthe 968 trans?
Freelancelance
Post  Hotrodz of Dallas Tue Dec 07, 2021 8:40 am
Freelancelance wrote:Do you recall the name of the company that regearscthe 968 trans?
https://advancedautomotion.com/shop/
Hotrodz of Dallas
Hotrodz of Dallas
