Fuel and Brake line mods
I ran my fuel and brake lines a little different from the rest of you.
I went to the parts store and bought a bubble ISO flare tool to cut and flare my brake lines.It is kind of hard right now to figure exact measurements due to not having an engine installed but it works alot better than bending the extra inches of brake lines.
I also ran my fuel filter off of the main porshe lines. I thought about running it in line with the frame rail but fear of hitting a speed bump changed my mind. Instead I ran it inside the passenger fender well behind the inner cover which still goes into place. The final placement of the pressure hose to the engine will be complete once I have an engine.
Re: Fuel and Brake line mods
Hi, what type of fittings did you use for both ends of the fuel filter? I can't find any that go from the quick-connect style to hose barb.
hooplajr5- Posts : 2
Firewall
What did you do at the firewall for the brake booster delete?
LStuner- Posts : 32
» Broken brake line right at MC, and other brake stuff
» fuel line conversion
