Early 944 Fuel Line Routing
BLUF: Should I reroute the fuel lines on 83 944 LS1 build? If so does anyone have ideas/experience/a picture?
I have an 83 that is deep in to engine bay prep for paint. I pre-planned, gutted, and prepped nearly all of my mounting spots for hoses and new hardware for the new engine just haven't figured out the fuel lines. It looks like the fuel lines may pass very close to my driver side exhaust/headers. I am concerned about the proximity to the heat. Should I be? Advance searching is not helping me to find this answer.
Thanks in advance for anyone who has advice!
-Rob
-Rob
rallen130- Posts : 4
Re: Early 944 Fuel Line Routing
FWIW - i adjusted the hard-lines to the right, and ran the hose on the inside of the strut tower. I will probably end up running all new lines at some point.
This picture should give you the idea:
George
George
LStuner- Posts : 32
LStuner wrote:FWIW - i adjusted the hard-lines to the right, and ran the hose on the inside of the strut tower. I will probably end up running all new lines at some point.
George
Hey George,
Do yourself a favor and remove that throttle body and make sure the butterfly screws are staked in. Some of that brand has had screws get loose and cause the throttle to stick way open, and some have come out completely and went into the engine. Otherwise they are decent throttle bodies.
Yep, you're not the first person to tell me that. I took the butterfly screws out a while back and used a good loctite and re-installed.
Hotrodz of Dallas wrote:LStuner wrote:FWIW - i adjusted the hard-lines to the right, and ran the hose on the inside of the strut tower. I will probably end up running all new lines at some point.
George
Hey George,
LStuner- Posts : 32
George, thanks bro. That engine bay looks great! Did you keep the fuel hard lines that run up the firewall in the stock location too?
-Rob
-Rob
George
Thanks! Yes i did re-use the original hard lines. I am also still using the original fuel pump, but i have a bosch pump ready to go in this winter. I never had fuel pressure drop, just want to get a bit more power out of this 5.3 and i think im close to the limit of the stock pump.
rallen130 wrote:George, thanks bro. That engine bay looks great! Did you keep the fuel hard lines that run up the firewall in the stock location too?
-RobLStuner wrote:FWIW - i adjusted the hard-lines to the right, and ran the hose on the inside of the strut tower. I will probably end up running all new lines at some point.
George
LStuner- Posts : 32
