Today at 6:37 am by Patb
» 5.3 conversion on 88 Turbo
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
fuel line conversion
Post  dallas on Sun Aug 09, 2009 9:04 am
How are you guys doing it? I've got the filter, got the tubes, using swagelok compression fittings. But how are you guys getting the fuel pump discharge line to the Corvette setup. Are you using a barb adapter to tube to compression then into filter? I saw a fuel injection conversion from "carb" And they used a line with a single barb on it at the pump with clamp. Does it stand up? the Porsche fittings are strange. Did you guys drop the pump and start from there? Thanks in advance! Alex
dallas
Re: fuel line conversion
Post  gt1scca on Sun Aug 09, 2009 9:45 am
Check here...
Post  dallas on Sun Aug 09, 2009 10:15 am
So I take it you guys are cutting the end off the line coming from the pump and inserting the new 12 inch line into it with clamps? I don't have enough space to get a compression fitting on the pump line even if I cut the nut off it. Pictures would help.
dallas
