High and low speed fan relays
I found this diagram showing how to hook up your fan relays on a GM car so that 1 fan comes on when the low speed is triggered and when the high speed is triggered both fans run at once. Here it is... This is what I'm finishing up this weekend... I'm getting close!
Re: High and low speed fan relays
K, I'm confused about the whole fan thing. I'm running two NA fans. I have them wired into ONLY two relays, each wired to PCM high and low outputs. I'm begrudgingly starting to understand that I need three relays-
BUT:
At the moment, neither fan turns on, even after getting up to temp.
So my questions is, with my current two relays, would a fan ever turn on at all? Or would my two relay approach mean that neither fan would EVER turn on?
And for a quick fix until I can wire up a third relay, are there reasons not to use one of those dual fan controllers w/a temp probe you stick in the radiator fin?
BUT:
Jasonscottw- Posts : 125
I didn't end up using that diagram, I used three relays to control the fans.
Did you check if you're getting a ground signal on the wire from the ECU when the engine is at temp?
If you take the wires off pin 85 and apply a known good ground to that pin, does the fan turn on?
This uses a 5 terminal relay for the "ON" on the right in this schematic. When the HIGH speed kicks in, it removes power from the first relay. This prevents power from being applied to both wires of the fan at the same time.
Today at 4:44 pm by JW1970
Today at 12:39 pm by Nath1142
