It's finally underway.
+2
dallas
6 posters
No, it actually started back June 19th. I finally started my gallery here. Hope the pics help those starting now. I'll post more as I finish up. Hope to be running by labor day. Wiring might be a pita though.
dallas- Posts : 69
Re: It's finally underway.
We'll I'm getting close. Down to 7 wires coming off the engine harnesstiil I fire it up.My question is, how to wire the fuel pump and fan relays. I had my ls harness modified and he left a wire that says fuel pump on it. I'm take a guess and say to connect it to terminal 85 on relay? And ground terminal 86? I'm using gt1scca's posting to admin for the corvette pinouts. Relay activation proceedure should be the same using my marked wires. I'm gonna try and use the wires marked high speed fan and low speed fan as trip wires for #1 fan and #2 fan using the fan relay This brings a question of where does the relay get it's ground as in the case of the fuel pump relay? Terminal 85 hot in start and run (keyed power?) term 86 computer trip wire, term 30 direct to battery, (no fuse?) term 87 straight fused power. Isn't a ground reqired? Help!
dallas- Posts : 69
I scrapped the Porsche fan relays and fan switch and used 3 relays to wire the fans in a low speed/high speed setup from the GM schematics (thanks to Skywalker for the schematic) What this does is put the fans in series for low speed operation, and then the both get 12 volts for high speed operation. The GM computer pulls the relays' coil to ground to activiate the relays. This setup is great, and if you have access to a tuning rogram (I have have HPTuners) you can program in the temp they come on, go off, and disable at a certain road speed ( I think defaualt was 30 or 35MPH) as they provide no benefit at speeds above that, as well as how long they run after the engine is shut off. Another benefit is if you are running A/C like I am, they will kick on when the GM computer has an A/C request signal.
Mike
Mike
relays
Are you still using the the Porsche fans? And where did you get the relays? Also did you use the Porsche dme relay for the fuel pump?
dallas- Posts : 69
Yes, I'm using the Porsche fans and a custom turbo sized radiator with the turbo fan shroud. The radiator is from Griffin, I had it made without the fan switch bung. The relays came from [You must be registered and logged in to see this link.] a buck a piece, plus I bought relays sockets, makes installation much cleaner. I am using the DME relay for the fuel pump.
Mike
Mike
Thanks, I'm using the stock turbo radiator and fans. Hope it works till I find another alternative. I found the site you mention. If you could get me the part numbers that would be great. I'm not too good on electronic stuff. Your setup sounds much cleaner. Gotta call on skywalker for the diagram.
dallas- Posts : 69
Rad
Tell us more about the Griffin. Was this a custom order? Can they produce another one like it? Cost?
968gene- Posts : 259
It a standard turbo replacement from Griffin, I just had them delete the fan switch bung and put in a petcock valve for draining, instead of the nylon bolt Porsche used. Cost was $445 plus $50 shipping. I originally sent them my S radiator to copy, they sent me back a turbo sized one. I decided to just keep it instead of dealing with the hassle of returning it and waiting on a new one. Good news for you N/A and S owners like me, just get a turbo lower radiator support, they go for 20 bucks or so used and the turbo radiator fits perfect! All my S ducting and the under engine cover fit as well.
Mike
Mike
It's alive!
When the smoke and dust blew out of that pipe, everyone knew it [u]wasn't the end of the line for that Porsche! Yep, fired it up yesterday! Gonna try to get a video. First I'd like to thank everyone that answered my sometimes crazy questions. I know I'm confusing at times. Thats the good. The bad is one of those pipes coming off the pan for the oil filter is leaking. I checked them when I installed it, but must have missed something. The leak is just above the fitting. I was carefull and used 2 wrenches when I tightened them. The only other thing is fan relays and tach wire. Not a real biggie. Again THANKS GUYS!
dallas- Posts : 69
Dallas, I had the same situation with the pipes on the oil pan leaking. Don't do what I did and naturally assume that the leak is coming from the AN fitting. I tried tightening the fitting, installing special (read hard to find) conical sealing washers, and still could not stop the leak. I finally flushed the area with brake parts cleaner to remove every trace of oil and let the car sit for about an hour. I then crawled underneath and looked closely to find that the leak was actually a bad weld between the tube and the pan. The weld was hidden where it was nearly invisible. Renegade took full responsibility for this and repaired the pan, but it still cost me about 6 weeks or more of downtime. Frustrating when you're so close to that first road test.
Bridar- Posts : 52
bad weld.
I'm really not sure where it was leaking. But it was above the fitting as you said. I used a bore scope I have to look as far around the pipe as I could. I saw a small hole like a pin. Not sure what they used to weld it. But I wasn't about to hold up progress right now so it got jb weld at top and bottom. I never liked the condition of the pan when I got it but the turn around time they gave me was not to my satisfaction. It will become a winter project. Now for the first drive!
dallas- Posts : 69
sounds like someone is using old coat hangers for tig rod!
944v8inDFW- Posts : 147
First ride.
All I can say is WOW! I had a friend video the first ride for me. Its a short 2 min. clip. I'll try to post as soon as I can. It's been a long time since I was grabbed by the seat of the pants and throw down the street, but to me thats what it felt like. A little getting used to the clutch. It seems to just grab sometimes instead of sliding in smoothly. The first ride made all the problems seem small. Thanks again too all that answered my crazy questions. Hope to post the video soon. Alex
dallas- Posts : 69
The video.
[You must be registered and logged in to see this link.] Here's the video. This is my first time doing one, so cut me some slack. Cecil B Demile I'm not!
dallas- Posts : 69
