CV axles
CV axles
While going throught the turbo body I have torn out the trans to do the 5th gear swap.I am not sure if I am seeing this right? is that axle broken at the hub?
In regards to this will the early cv fit the 86 turbo?
Also i expect the answer to be the same with the outer tie rods, is this correct?
