» Heat stuck on high
HIGH HP Chromoly AXLES 85.5-up EmptyYesterday at 2:11 am by Porsche951toLS3
» Selling TPC LS Swap Kit + Ceramic Headers + SPEC Clutch / Flywheel + Hydroboost + More
HIGH HP Chromoly AXLES 85.5-up EmptyFri Jul 19, 2019 11:42 pm by matt889
» WTB: TPC LS Swap Kit
HIGH HP Chromoly AXLES 85.5-up EmptyFri Jul 19, 2019 11:24 pm by Zach968
HIGH HP Chromoly AXLES 85.5-up EmptyWed Jul 17, 2019 10:02 pm by sharkey
» Hydroboost low pressure port
HIGH HP Chromoly AXLES 85.5-up EmptyWed Jul 17, 2019 3:03 pm by rdanford
» Alfa Romeo 2.5L V6 --> '78 924
HIGH HP Chromoly AXLES 85.5-up EmptyMon Jul 15, 2019 5:11 pm by porschekid7
» WTB: LS Swapped 944
HIGH HP Chromoly AXLES 85.5-up EmptyMon Jul 15, 2019 4:57 pm by porschekid7
» 1987 Porsche 944 S - Transaxle FOR SALE
HIGH HP Chromoly AXLES 85.5-up EmptySun Jul 14, 2019 12:55 pm by MotoRider42HC
» V8 Swap Project Car Swap Out
HIGH HP Chromoly AXLES 85.5-up EmptySun Jul 14, 2019 6:12 am by DirtRocket
» Transaxle rebuild
HIGH HP Chromoly AXLES 85.5-up EmptyFri Jul 12, 2019 8:12 pm by Jasonscottw
July 2019
Page 1 of 3 1, 2, 3  Next
HIGH HP Chromoly AXLES 85.5-up Empty HIGH HP Chromoly AXLES 85.5-up
Post  xschop on Wed May 11, 2011 8:21 pm
I will build these on request and will take 7-10 days lead time. I use BRAND NEW (not reman) Type II heat-treated CV's with the Larger Diameter Balls and thicker cages along with new through-hardened 4340 Chromoly axles that are chrome plated after the heat-treat process for corrosion resistance. These have no stress-risers in the circlip machined areas of the shaft and can handle much more torque than factory axles. They will come pre-assembled with all brand-new N-butyl rubber boots and new outer CV to hub gaskets as well as CV axle grease for each CV joint......
$640/pair shipped anywhere in the U.S.
$670/pair shipped to CANADA
Just send PM
HIGH HP Chromoly AXLES 85.5-up Empty Re: HIGH HP Chromoly AXLES 85.5-up
Post  cfgioja on Wed May 11, 2011 9:45 pm
those look nice, now if I could afford them. I hope I dont need them one day. Keep up the good work Robert.
Post  kelleysj on Thu May 12, 2011 5:21 am
I want some but it will have to wait awhile.
kelleysj
kelleysj
Post  spence on Thu May 12, 2011 7:04 am
Those look very nice... Maybe next year. I like the fact you remembered to include a shipping cost to Canada! Most of the time we're forgotten...
Post  xschop on Thu May 12, 2011 9:53 am
The "Stage 8" Locking CV bolts will work with these CV's and boot flanges as well Very Happy
HIGH HP Chromoly AXLES 85.5-up Empty Very cool
Post  968gene on Thu Jun 02, 2011 9:52 pm
these look great. Can you do a 968 set as well? How much stronger do you think these are?
968gene
968gene
Post  robstah on Fri Jun 03, 2011 4:19 am
Hmmm, no caps/sealed design? I hate having to deal with the grease when installing/removing these axles. Never had a greasy mess with the BMW ones I normally deal with.
Post  xschop on Fri Jun 03, 2011 5:18 am
Just the axles alone are 40-50% stronger and tougher because of the 4340 Chromoly steel. Additionally the stress-riser areas are eliminated that is in the factory 944 axle design. I've seen a couple break on Non-V8 cars. There is even a few pics in a user gallery here....
To Rob, I'm not sure if end caps would fit these CV's or the outer drive flanges of the 944. There is a lip on the outer drive flanges that steps out.
And at Gene, Yes, I can build them for the 968 if I had the axle dims. I asked before if anyone knew if the 968 axle lengths were the same on passenger and driver sides. As long as the 968 CV's are 86mm PCD then they too can take a Type 2 CV upgrade.
I adjusted the shipping cost.
Post  xschop on Fri Jul 01, 2011 3:26 pm
I have another fully assembled 4340 axle set with Brand new heat treated Type 4 cv's (0.69" balls) and new neoprene boots and moly grease minus the CV bolts..... I'll ship them anywhere in the US-48 for $600...just PM. I'll post a pic shortly Very Happy
Post  xschop on Sun Jul 03, 2011 7:23 am
This set is SOLD
Post  eclou on Mon Jul 25, 2011 7:29 pm
those look awesome!
eclou
eclou
Post  xschop on Mon Jul 25, 2011 10:00 pm
Thanks, I would have busted a factory one the way I jump the tracks by my house acting like Bo and Luke Duke. I've caught air a few times Twisted Evil
Post  cfgioja on Mon Aug 01, 2011 6:02 pm
those say 85.5 up are they made to fit a 86 turbo? I know they have some early stance to them.
Post  modenas on Mon Aug 01, 2011 7:05 pm
those tracks by your house are scary! sick work once again
modenas
modenas
Post  xschop on Mon Aug 01, 2011 8:15 pm
Yeah they fit the 86 Turbo too. Sorry yours exploded, that's what happens when you stick in 4 more cylinders Laughing
HIGH HP Chromoly AXLES 85.5-up Empty 4340 Chromoly axles
Post  Mike951s on Wed Aug 03, 2011 2:29 pm
I have a 1989 951s running 18" Hoosiers. My issue is with the breaking the cages and pitting the balls especially on the left side. On occassion I can damage an axle after less than 60 minutes of racing.
Ideally after every race weekend (about 90 minutes total run time) the axles are inspected, cleaned, repacked with new grease and rotated from left to right.
Do you have any specs on the CV axle grease? I understand that the type of grease is crtical and that during the Turbo Cup days many of the teams had developed their own formulations.
What are the diameter of the balls? How much larger are the balls compared to stock? Are they the same material?
What is the thickness of the cage? How much thicker is the cage as compared to stock and is the material the same as the stock ones?
How do these axles compare to the ones that Lindsay Racing is offering that are guaranteed for one full year of racing?
xschop wrote:I will build these on request and will take 7-10 days lead time. I use BRAND NEW (not reman) Type II heat-treated CV's with the Larger Diameter Balls and thicker cages along with new through-hardened 4340 Chromoly axles that are chrome plated after the heat-treat process for corrosion resistance. These have no stress-risers in the circlip machined areas of the shaft and can handle much more torque than factory axles. They will come pre-assembled with all brand-new N-butyl rubber boots and new outer CV to hub gaskets and new hardened ALLEN-HEAD CV bolts as well as CV axle grease for each CV joint......
Just send PM
Mike951s
Post  xschop on Wed Aug 03, 2011 2:50 pm
I don't build the CV's just the axles and they are solid, thru hardened 4340 steel. TonyG said he busted one of his GKN axles and it was HOLLOW.... I just install Type 2 CV's with .75" dia. balls (0.688 is 944/951 type 4).... I personally took apart a brand new set of Empi's and a brand new set of GKN/LOBRO type 2's and the cages are thicker and wider than the Type 4's that came out of my car. I have been trying to break them under hard left and right hand turns under full throttle and haven't busted one yet. I did a 5000 rpm drop just this morning and got bite on the hot asphault. The Chromoly "spools" and has a different feeling when launching than the stock axles, which will save the trans under severe punishment. Also I have a Billet-polyurethane mount that I designed and installed and that in itself keeps the CV's from binding and exploding. With the rubber trans mount I could push it by hand 1/2" to 5/8" side to side just hanging under the car..... As for LR, I don't know, but they cost twice as much and they don't build their CV's either.
Post  xschop on Wed Aug 03, 2011 3:35 pm
I just weighed a modded axle....... only 4.4 LBS each (no CV's)
Post  LEEEZARD7 on Thu Aug 04, 2011 3:43 am
after i get started on my build next wk i will likely take a set if you have them in stock.
LEEEZARD7
Post  xschop on Thu Aug 04, 2011 9:33 am
I have a set ready to assemble. Since you're in my neck of the woods, disreguard the $40 shipping for local pic-up.
Post  kelleysj on Wed Dec 14, 2011 8:47 pm
Are you still building these?
kelleysj
kelleysj
Post  xschop on Wed Dec 14, 2011 8:54 pm
I am still building these and always will on request. I am using EMPI TYPE-II CV's as they are the best built and equal the quality of GKN/Lobros. I've measured tolerances between 3 different manufactures (for the Type 2's)
Post  Rich L. on Sun Dec 18, 2011 10:54 am
My goodness those are beautiful. On my list of upgrades to do after this thing is running.
HIGH HP Chromoly AXLES 85.5-up Empty shafts
Post  89 944 on Sat Jan 07, 2012 5:08 am
are you able to make one that would adapt to the 930 trans stubs? I would be interested!
89 944
Post  Howellls2 on Mon Jan 23, 2012 7:48 pm
I'd like a pair, I have a 1988 turbo s trans in my 1992 968. Pay Pal ?
Howellls2
