Who makes the best vacuum contolled heater valve?
The heater valve in my car has started leaking. What application is the best choice for a new valve?
gwistrup- Posts : 113
Re: Who makes the best vacuum contolled heater valve?
I use the metal 928 one. Works great.
https://www.pelicanparts.com/More_Info/928MHEATRVLV.htm?pn=928M-HEATRVLV&gad_source=1&gclid=CjwKCAiAqY6tBhAtEiwAHeRopZiC0oen9i-mB0E0zXygmCKPH999HHYmFhN2-a86MLulmeRyehqMcBoC7eUQAvD_BwE
Rob44- Posts : 35
RE: hot water valve
How did you plumb that style valve? The valve I have has four connections so that when the valve is not in the heat position, the heater circuit bypasses back to the engine.
The LS engine doesnt have a separate cooling system bypass hose. gm vehicles have coolant flowing through the heater core all the time and use a blend door in the heater box to control heat. as a result, gm engineers decided to use the heater core as the bypass circuit in the cooling system.
if you use a simple on/off coolant valve it will cause an LS to run hot when you turn the heat off because there is no coolant flow through the motor. a 4 port valve always allows coolant to flow, it just bypasses the heater when its shut off.
i use an off the shelf valve for a chevy pickup, somewhere in the 90s. no idea the brand.
RE: Heater valve
Thank you for your replies. I dug a little deeper and found that a heater valve from a pickup in the late '90's with an LS engine will fit. I got one at NAPA.
Sounds like you found the heater valve you need.
I used the valve Kent provided in his TPC kit and it was one of the 2 brands I could identify from other vendors.
The link below is the installation process I followed...if you haven't installed the valve already, it might prove helpful to get all the hoses and vacuum lines back where they belong.
https://944hybrids.forumotion.com/t2585p175-ray-s-1987-944-ls1-build-swap#40443
Raymond-P- Posts : 384
RE; Heater valve
Thanks Raymond. The new valve from NAPA is in the car and not leaking.
» Heater control valve vacuum connections
» Diagram for heater lines/vacuum
» overheating-Continued :P
Today at 11:46 pm by Raymond-P
Today at 11:09 pm by Raymond-P
Today at 10:59 pm by Raymond-P
Today at 4:44 pm by JW1970
