Heater control valve vacuum connections
Hi
My heater (89 turbo) is permanantly blowing hot. So I'm wondering if the vacuum connections are right.
I'm fairly sure the hose connections are right.
Is there a diagram or such like as Greg's manual does not mention these connections.
Maybe there is an alternative solution?
Thanx
Q
Thanx
Q
Re: Heater control valve vacuum connections
It fails hot. If the vacuum line to it collapses it will open the valve to full hot.
Theres a little plastic clip that is common to break on these. You can just see it if you look up under the drivers side dash towards the radio. When they break they fail to open like Arthropraxis said.
» Who makes the best vacuum contolled heater valve?
» Diagram for heater lines/vacuum
