» Early 944 Fuel Line Routing
Diagram for heater lines/vacuum EmptySat Feb 15, 2020 4:35 pm by rallen130
Diagram for heater lines/vacuum EmptyFri Feb 14, 2020 8:37 pm by VWTortuga336
» 1984 Porsche 944 with 1995 LT1 motor for sale
Diagram for heater lines/vacuum EmptyThu Feb 13, 2020 12:47 am by jerry944
» Wizard Cooling Radiators!!
Diagram for heater lines/vacuum EmptyWed Feb 12, 2020 12:32 pm by 87944turbo
» Oil and Cooling question
Diagram for heater lines/vacuum EmptyWed Feb 12, 2020 6:01 am by gwistrup
» V8 Conversion Parts
Diagram for heater lines/vacuum EmptyTue Feb 11, 2020 10:49 am by Chevota350
» Coil mounting pictures
Diagram for heater lines/vacuum EmptyMon Feb 10, 2020 5:50 am by gwistrup
» 82 924 with AUX Audi V8.
Diagram for heater lines/vacuum EmptyFri Feb 07, 2020 11:40 pm by Golten1986
» 14 Pin Connector - Check Please
Diagram for heater lines/vacuum EmptyFri Feb 07, 2020 9:50 am by Hotrodz of Dallas
» 968 Swap Wiring Checklist/Questions
Diagram for heater lines/vacuum EmptyWed Feb 05, 2020 2:39 pm by Kiltacular Jim
February 2020
3456789
10111213141516
17181920212223
242526272829
Diagram for heater lines/vacuum Empty Diagram for heater lines/vacuum
Post  C4924S on Thu Oct 17, 2019 5:10 pm
Hello! I have an 86 951, just wondering if there’s a nice diagram out there of how the heater lines are suppose to go with the heater valve, along with the vacuum lines?
C4924S
C4924S
Diagram for heater lines/vacuum Empty Heater Lines Diagram
Post  Porsche951toLS3 on Wed Oct 23, 2019 2:30 pm
LOOK AT THE HVAC HEATER RIGHT SIDE AS THE TITLE:
http://www.clarks-garage.com/shop-manual/hvac-01.htm
This is how I figured mine out.
Porsche951toLS3
Porsche951toLS3
http://n4cr@comcast.net
Diagram for heater lines/vacuum Empty Re: Diagram for heater lines/vacuum
Post  C4924S on Wed Oct 23, 2019 2:41 pm
Awesome thanks! So if I’m understanding it correctly, on #4 I’m supposed to supply vacuum to it from the engine? And then #5 obviously goes to the heater valve.
C4924S
C4924S
Diagram for heater lines/vacuum Empty Vacuum Lines for HVAC
Post  Porsche951toLS3 on Wed Oct 23, 2019 9:30 pm
Correct. #4 in the diagram or top one gets the vacuum from the engine. As the #4 hose goes through the HVAC, the #5 will variably control the heater valve. Many have talked about putting a manual shutoff to your heater on the HVAC side of the heater valve in the summer, this way the water can still flow on the engine side of the heater valve which has to do with water going back to the thermostat. I only mention this for you to find more stuff to read..............
Porsche951toLS3
Porsche951toLS3
