DBW gas pedal bracket solutions for an S2?
Swapping in a LS3 crate motor into an 89 944 S2. Wondering if any one has guidance on fabricating a DBW gas pedal bracket specially for the S2 (under the impression that the S2 differs from the other models)?
Any help is appreciated
dcoutofstep- Posts : 12
Re: DBW gas pedal bracket solutions for an S2?
Using the advanced search function,
in the header above, yeilded several results.
This is a good start - [You must be registered and logged in to see this link.]
dcoutofstep wrote:Swapping in a LS3 crate motor into an 89 944 S2. Wondering if any one has guidance on fabricating a DBW gas pedal bracket specially for the S2 (under the impression that the S2 differs from the other models)?
Yes, you'll see I also posted in that thread. My understanding is the S2 pedal config is unique, so just trying to see if anyone has any further specifics.
948 wrote:Using the advanced search function,
This is a good start - [You must be registered and logged in to see this link.]dcoutofstep wrote:Swapping in a LS3 crate motor into an 89 944 S2. Wondering if any one has guidance on fabricating a DBW gas pedal bracket specially for the S2 (under the impression that the S2 differs from the other models)?
Today at 4:44 pm by JW1970
Today at 12:39 pm by Nath1142
