» JP's LS1 Conversion
Yesterday at 8:32 pm by jpkinerk
Yesterday at 8:13 pm by gdopnt
Yesterday at 9:56 am by superman22x
» LS3 Exhaust
Sat Jan 20, 2018 11:12 pm by sharkey
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
» alignment specs
Fri Jan 19, 2018 4:22 pm by Hotrodz of Dallas
» 1984 Gen IV 5.3 Swap
Fri Jan 19, 2018 2:03 pm by superman22x
January 2018
LT1 A/C Bracket
LT1 A/C Bracket
Post  Oso on Sat Feb 20, 2010 11:51 am
Hi, I have been looking for an A/C bracket for a while now. Autozone doesn't sell it and tells me to go to GM. Does anyone have a picture of the stock bracket or a part number for one that fits in the 944. I have a 96 LT1. I found a dynomax one [You must be registered and logged in to see this link.] but it doesn't look right, even though they told me it would fit.
Oso
Re: LT1 A/C Bracket
Post  gt1scca on Sat Feb 20, 2010 12:35 pm
Nook and Tranny, LLC
93, 94, 95, 96, 97 LT1 Camaro Z28
93, 94, 95, 96, 97 LT1 Firebird Formula, Trans Am
EDIT: This still must be modified to mount the alternator lower...
Re: LT1 A/C Bracket
Post  Oso on Mon Feb 22, 2010 12:15 pm
Thanks!! For some reason I thought my alternator and compressor were on diff sides. Embarassed
Oso
Re: LT1 A/C Bracket
Post  brazuca on Mon Mar 08, 2010 7:52 am
Can i still use the original alternator or need to be smaller ? How much do i need to modify the bracket , is only the top right ?
brazuca
Re: LT1 A/C Bracket
Post  Dawgz83948 on Mon Mar 08, 2010 9:30 am
You need to use the alternator from a Buick Century 4cyl if my memory serves me right. edit: apparently it's the v6 version that is needed.
Re: LT1 A/C Bracket
Post  944-LT1 on Mon Mar 08, 2010 10:14 am
Yup... Timmys right as per usual (except what I used was the V6 unit). I simply asked for a 1993 buick century custom with the 3.3L 3300 V6 engine and they gave me one for ~80 bucks and a lifetime warranty. They wanted a core so I gave them an old alternator from a jeep. Laughing They had no problem with that....they just want an alternator back.
Delco CS130 Series
ACDELCO Part # 3342419A
Mounting ears must be at 6 and 12 o'clock.
BUICK CENTURY CUSTOM (1992 - 1993)
BUICK CENTURY LIMITED (1992 - 1993)
BUICK CENTURY SPECIAL (1992 - 1993)
BUICK SKYLARK 1992
BUICK SKYLARK CUSTOM 1993
BUICK SKYLARK GRAN SPORT (1992 - 1993)
BUICK SKYLARK LIMITED 1993
OLDSMOBILE ACHIEVA S (1992 - 1993)
OLDSMOBILE ACHIEVA SC (1992 - 1993)
OLDSMOBILE ACHIEVA SL (1992 - 1993)
OLDSMOBILE CUTLASS CIERA 1992
OLDSMOBILE CUTLASS CIERA CRUISER S (1992 - 1993)
OLDSMOBILE CUTLASS CIERA CRUISER SL (1992 - 1993)
OLDSMOBILE CUTLASS CIERA S (1992 - 1993)
OLDSMOBILE CUTLASS CIERA SL (1992 - 1993)
PONTIAC GRAND AM GT (1992 - 1993)
PONTIAC GRAND AM SE (1992 - 1993)
Just make sure whatever you get, that it has the 12 o'clock mounting ears with 6-9/16" center to center.
Re: LT1 A/C Bracket
Post  944-LT1 on Mon Mar 08, 2010 10:19 am
Oh yeah, you do have to cut the bracket. The one that nearest the valve cover or rightmost as looking at the bracket on the car.
Some have had great luck with that aluminum braze stuff... [You must be registered and logged in to see this link.]
Others have simply drilled holes and used metal braces or flat stock (commonly found at lowes and the like).
If you dont plan on running AC, PS, or simply just running an alternator, you may simply want the CS130 alternator and a alt only low mount kit which I believe Greg/Admin makes??? This is what I did and used alterstarts low mount kit [You must be registered and logged in to see this link.]
Re: LT1 A/C Bracket
Post  brazuca on Wed Mar 10, 2010 5:07 pm
THANKS Very Happy You guys always reply with the solution for everything , diagrams, pictures, PN's , etc. Im glad to be part of this forum Very Happy
brazuca
Re: LT1 A/C Bracket
Post  brazuca on Sat Nov 20, 2010 8:38 am
We lowered the alternator , but now the belt is too long . Can I just take a measurement using a rope and go to autozone to look for a new belt ? Does anybody have a PN for a belt that fits , after cuting the bracket ?
brazuca
Re: LT1 A/C Bracket
Post  brazuca on Sat Nov 20, 2010 8:40 am
Forgot the details, we are running ac and ps.
brazuca
Re: LT1 A/C Bracket
Post  Admin on Sat Nov 20, 2010 9:59 am
Just measure the length you need and go to the parts store, take the old belt and tell them that you need that style and your new length.
Re: LT1 A/C Bracket
Post  brazuca on Sat Nov 20, 2010 10:30 am
Thanks Very Happy !
brazuca
Re: LT1 A/C Bracket
