Today at 7:52 pm by matt889
» New here needing help
Today at 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Yesterday at 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
May 2018
78910111213
14151617181920
21222324252627
28293031
cv joint axles
cv joint axles
Post  dallas on Wed Sep 09, 2009 11:28 am
I remember a while ago , someone on one of these sites developed a tranny brace that helped stop the dr. side cv joint breakage. Has anyone heard anything as to its long term success? I think the guy drag raced it. Seems these axles don't stand up to much abuse.
dallas
Transaxle torque bar
Post  968gene on Wed Sep 09, 2009 12:09 pm
I spoke to someone who is running a transaxle torque bar for his street/track car. How much interest is there in having one? I will be doing this for my track car. If interested, let me know so that a batch can be made. xs, any interest on your part? I can get pics and dims to start the process.
968gene
Re: cv joint axles
Post  Admin on Wed Sep 09, 2009 1:55 pm
With enough power you'll still break the CV, I broke the cage on one just giving someone a test ride! Shocked
Re: cv joint axles
Post  Johnny Johnny on Wed Sep 09, 2009 2:04 pm
968gene wrote:I spoke to someone who is running a transaxle torque bar for his street/track car. How much interest is there in having one? I will be doing this for my track car. If interested, let me know so that a batch can be made. xs, any interest on your part? I can get pics and dims to start the process.
I'd be interested as well. I've got a solid transaxle mount on mine, but I'm just not convinced that a second brace is not needed. Would rather over engineer it.
Johnny Johnny
Re: cv joint axles
Post  xschop on Wed Sep 09, 2009 3:30 pm
Yeah, throw it out there an let it be mulled upon. It may be possible to just make a simple threaded rod with a heim joint on both ends, one attached at the mount, the other to the frame?
Re: cv joint axles
Post  Johnny Johnny on Wed Sep 09, 2009 4:01 pm
Aluminum rod threaded at each end with wrench flats, similar to a KLA strut brace.
Johnny Johnny
Re: cv joint axles
Post  dallas on Wed Sep 09, 2009 6:41 pm
I have a pic of the brace that I saw a while ago. It's pretty easy to make. However , its on a car that that looks like a track car. I think the muffler in its stock location might be a problem. At least it seems that way on mine. I'm gonna try again to post it in my gallery. It doesn't seem to want to post. I keep getting a 312 none of your pictures have posted, after I hit save. Any ideas what I'm doing wrong?
dallas
transbracket pictures
Post  968gene on Wed Sep 09, 2009 7:19 pm
Here are a few pictures (fabricator unknown). we should concentrate on the passenger side to avoid the muffler. two brackets and a rod. fairly straight forward. xs?
968gene
Re: cv joint axles
Post  968gene on Wed Sep 09, 2009 7:20 pm
by the way, this thread is in the wrong area.
968gene
Re: cv joint axles
Post  dallas on Wed Sep 09, 2009 7:53 pm
I didn't know we had a seperate topic for this . I just posted it on the ls site since it is an ls conversion. Thanks for putting where it belonged. I'm gonna try and post the picture I have. Tried but I guess the file is too big. The pic is 900 kbs maybe thats why it won't upload. BTW thats a nice setup. It clears the muffler.
Last edited by dallas on Wed Sep 09, 2009 7:58 pm; edited 1 time in total (Reason for editing : added a sentence)
dallas
Re: cv joint axles
Post  dallas on Thu Sep 10, 2009 7:01 pm
Since my topic is cv joint axles, does anyone know a supplier of gkn motorsports axles for our cars?
dallas
Re: cv joint axles
Post  968gene on Thu Sep 10, 2009 7:24 pm
Your topic is CV joints, but your original post was about the trans bracket Laughing
If the trans bracket solves the problem, why investigate (and pay for) mega axles???
968gene
Re: cv joint axles
Post  dallas on Fri Sep 11, 2009 8:01 am
Well I snapped an axle yesterday. It snapped right at the end of the spline on right next to the collar. Most guys say we take out the inner cage of the cv joint correct? The thing is I've never pulled a hole shot. This was just a half throttle excursion from a roll in first gear. Maybe it was a defective axle, there was a porosity spot just off center. I will post a picture of it tonight. The cage was fully intact. I'm supposed to be 350hp and 365 tq. Some are way above that here. I pm'd Michaelb, but haven't heard back. His axles were "driveline motorsports" I heard they are expensive.
dallas
Re: cv joint axles
Post  Johnny Johnny on Fri Sep 11, 2009 10:17 am
I smell 'group buy'... sunny
Johnny Johnny
Re: cv joint axles
Post  948 on Fri Sep 11, 2009 11:47 am
dallas wrote:Well I snapped an axle yesterday. It snapped right at the end of the spline on right next to the collar. Most guys say we take out the inner cage of the cv joint correct? The thing is I've never pulled a hole shot. This was just a half throttle excursion from a roll in first gear. Maybe it was a defective axle, there was a porosity spot just off center. I will post a picture of it tonight. The cage was fully intact. I'm supposed to be 350hp and 365 tq. Some are way above that here. I pm'd Michaelb, but haven't heard back. His axles were "driveline motorsports" I heard they are expensive.
Tell me; was this the drivers side?
If so, are there marks in the center of the concaved section of the outer drive spindle? Also is the end of the shaft spline, outer, peened over?
When the transaxle moves over to the drivers side, under load, one of two things happens.
1. The CV's compress(plunge) and the cage limits further movement and will usually break because of the axial force.
2. The CV's compress(plunge) and the end of the splined shaft will contact the concaved section of the outer drive spindle. <== I had this on my car when it was still a Turbo; it was reduced by making a solid mount.
The solid bar should eliminate these two problems.
930 CV's have more plunge, operating angle and strength than the 944 (Type 4) style CV's, but they are 108mm in diameter with a larger bolt circle.....I have found an off the shelf solution for the outer spindles but no solution for the inner drive flanges
Re: cv joint axles
Post  skywalker01 on Fri Sep 11, 2009 11:48 am
I'd definitely be interested !! Very Happy
skywalker01
Re: cv joint axles
Post  dallas on Fri Sep 11, 2009 4:20 pm
I posted pic's in my gallery of the axle. They're a little blurry but you'll get the idea. I'm thinking defect.
dallas
Re: cv joint axles
Post  Admin on Fri Sep 11, 2009 7:45 pm
If you guy's can get me some good pictures of the brackets I can make them. The rod and hardware should be off the shelf type stuff.
Re: cv joint axles
Post  robstah on Sat Sep 12, 2009 3:12 am
Why not just fill in the mount with urethane? I hope that's what you guys are talking about. Check McMaster with part # 8644K11. There are people on RL that track their 944s and have yet to have this problem. 30-40 dollars later should have a solid mount in your hands.
Re: cv joint axles
Post  dallas on Sat Sep 12, 2009 9:27 am
Is that your mt? Zoom out a little. Napa has an adjustable bar with 2 heim joints. The brackets will have to be made up. I like the one in the above pics. But is that crossmember stong enough? Mine is thin guage stamped steel. Gonna try and make brkts. Oh btw ,heard back from gkn motorsports, about axles. Told me my letter was forwarded, and wanted to know yr, and model. Let you know when I do.
dallas
trans bracket
Post  968gene on Tue Sep 15, 2009 7:08 am
Solidifying the mount is only 1/2 the issue. The bracket triangulates the trans and that is what we need to keep the entire unit from compressing the driver's side CV joints. I like the trans to crossmember rod and brackets. This looks like the easiest fix.
968gene
Re: cv joint axles
Post  turbobob924 on Sat Oct 10, 2009 12:51 pm
this is interesting. Something that I did was that I had both the center trans mount and the early outer mounts on the transaxle. I also filled all the rubber mounts with the 3m window weld. I have blowup up the ring and pinion without breaking any CV's!
As and FYI, I put down over 560ft lbs to the wheels too!
turbobob924
http://www.turbo924.com
Re: cv joint axles
