Early 944 LS fuel pump and tach wiring
I have a 1983 944 and I'm in the middle of a LM7 swap and getting around to the wiring now. I've seen tons of coverage on how to wire a late 944 but not so much on the early cars.
I'm using a factory GM PCM to run the engine and want to know which wires need to be connected from the back of the factory 944 tach to the GM pcm to make it work.
Also, does the positive fuel pump wire on the 944 body harness simply get connected to fuel pump+ wire on the pcm harness?
Any help is greatly appreciated
-Steve
-Steve
1984944ny- Posts : 2
Re: Early 944 LS fuel pump and tach wiring
https://rennlist.com/forums/944-and-944s-forum/1237035-1983-944-ls-swap-tach-question-and-help.html
And you'll need to wire in a relay for the fuel pump.
Thank you very much for all of your help!
Painless wiring has a pretty easy and straightforward fuel pump relay kit, you can run the trigger wire from the pcm or switched 12v from the key. For Tach to work I needed to use the Dakota Digital unit, I run an Holley Terminator X.
alex456gt- Posts : 11
1984944ny likes this post
