Early Tach not working with LS3?
I'm finally getting around to wiring in all my gauges, and one issue I have is that the early tach is not working with my LS3. I verified my tach output from my Gen IV controller is working by using a Sunpro Tach with a 470ohm resister. But wiring the same setup into the thin green wire in the 9 pin connector on the firewall did not seem to work. Am I doing something wrong with my wiring?
superman22x- Posts : 272
Re: Early Tach not working with LS3?
Got it all working... Turns out the 12V switched signal to the tach is disconnected somewhere. Maybe when I removed the DME and engine harness? I put 12v to pin 5, and the tach works. Now I just need to wire it properly.
Pin 5 on the 9 pin connector or at the Gauge itself?
superman22x wrote:Got it all working... Turns out the 12V switched signal to the tach is disconnected somewhere. Maybe when I removed the DME and engine harness? I put 12v to pin 5, and the tach works. Now I just need to wire it properly.
LStuner- Posts : 32
superman22x wrote:Yep, that's it.
Which one superman22x? Did you add 12v at the 9 pin connector under the hood, or was it at the back of the gauge?
George
LStuner- Posts : 32
Today at 9:56 am by ndog52
