Today at 12:30 pm by sharkey
Today at 8:54 am by Rich L.
Yesterday at 5:04 pm by AMFCSL
» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Early 944 electronics tach?
Post  joecitizennn on Sun Mar 11, 2012 8:23 pm
Anyone have a good way to make the early 944 tach work with the lt1? I have the tach output from the ECM hooked up to my tach but of course it reads high. If you adjust the tach to the correct idle it still shows about 1000K too high at mid range and 2000k high at upper range.
joecitizennn
Re: Early 944 electronics tach?
Post  spence on Mon Mar 12, 2012 6:01 am
You can add a resistor or add a tach convertor from dakota digital... I just bought a tach convertor from dakota digital.
Post  Admin on Mon Mar 12, 2012 8:17 am
Do a search, this has been gone over a lot in the past.
Post  joecitizennn on Tue Mar 13, 2012 7:41 am
Admin wrote:Do a search, this has been gone over a lot in the past.
I must suck at searching because all I came up with was for the late model cars.
joecitizennn
Post  laptop_geek on Tue Mar 13, 2012 2:34 pm
Here is what I came up with.
This is for the late cars, but gives you the general idea, I think.
One problem here is the old site is down, and I've found alot of links to there that pertain to this topic.
laptop_geek
