Clutch replacement
Clutch replacement
Can somebody tell me if I can pull my transaxel and Slide the torque to back to replace the clutch
Michael Bivins- Posts : 20
Re: Clutch replacement
Michael Bivins wrote:Can somebody tell me if I can pull my transaxel and Slide the torque to back to replace the clutch
Yes you can. Once the torque tube is loose, slide it back until the crash hooks on the tube are back far enough to rotate the tube 180 degrees. Then it will slide back enough to remove the bellhousing.
