Replacement Radiator EmptyToday at 9:51 am by kevin924kevin
Replacement Radiator EmptySat Nov 16, 2019 9:00 am by j7wolfe
Replacement Radiator EmptyFri Nov 15, 2019 6:34 pm by Hey_Allen
» LS engine & Trans "upfront", Mustang IRS in the "rear"
Replacement Radiator EmptyMon Nov 11, 2019 5:59 pm by sparkydog
» WTB: Trailing Arm Bushings
Replacement Radiator EmptyMon Nov 11, 2019 9:18 am by Hotrodz of Dallas
» 82 924 with AUX Audi V8.
Replacement Radiator EmptySun Nov 10, 2019 2:35 pm by Golten1986
Replacement Radiator EmptySun Nov 10, 2019 5:13 am by superman22x
» Introduction/CA-SMOG '86 turbo
Replacement Radiator EmptySat Nov 09, 2019 8:29 pm by pormgb
» 944-LT1 LS3 Conversion
Replacement Radiator EmptySat Nov 09, 2019 7:49 pm by Ordie792002
» Lexus BBK Big Brake Kit
Replacement Radiator EmptySat Nov 09, 2019 6:19 pm by Red944ls1
November 2019
Replacement Radiator Empty Replacement Radiator
Post  knucklehead12 on Thu Jun 06, 2019 8:48 pm
My 89 turbo radiator started leaking at the end tanks and the shop said it is done. After reading all the radiator posts, still don’t know what to do. Leaning towards this one from Summit
The other Griffin that has been discussed is no longer available. This one:
Any help would be appreciated. I have a LS2 swap that is almost done with the exception of this and the gas pedal
Lee
knucklehead12
Replacement Radiator Empty Another radiator option
Post  knucklehead12 on Thu Jun 06, 2019 9:04 pm
Another option I found is:
knucklehead12
Replacement Radiator Empty Re: Replacement Radiator
Post  87944turbo on Fri Jun 07, 2019 9:04 am
I'm curious to hear responses as well. Mine is still holding up, but is definitely on my radar for replacement.
87944turbo
Post  matt889 on Fri Jun 07, 2019 8:44 pm
doesnt kent sell a wizard radiator for the swaps ?
matt889
Post  Rich L. on Fri Jun 14, 2019 10:55 am
I run the "Wizard" radiator from Lindsey Racing:
Post  Hotrodz of Dallas on Wed Jun 19, 2019 10:01 am
Kent has radiators for both standard turbo water outlet locations, and for LS outlet locations. These are full aluminum radiators. I've used both and they work really well.
Hotrodz of Dallas
Hotrodz of Dallas
Post  87944turbo on Wed Jun 19, 2019 10:53 am
Bob, do you have a link or contact information you could post? TIA.
87944turbo
Post  Hotrodz of Dallas on Wed Jun 19, 2019 11:20 am
Hotrodz of Dallas
Hotrodz of Dallas
Post  MotoRider42HC on Mon Jul 01, 2019 8:26 pm
CAUTION on the TPC radiator!
The one they sent me won't even fit into my car, and the brackets they provided don't fit at all.
MotoRider42HC
MotoRider42HC
Post  Hotrodz of Dallas on Tue Jul 02, 2019 7:46 am
MotoRider42HC wrote:CAUTION on the TPC radiator!
I have installed several of these and they do require a little work on the radiator support to make them fit. But otherwise they fit well, and the brackets fit exactly as intended.
Hotrodz of Dallas
Hotrodz of Dallas
