What's Wrong with my Tach?...Help
Not sure what is going on with my tach. It does not produce the right response very sensitive. A 2k idle sounds more like 800 or so. Also it revs at a past the marker and it sounds like maybe 5-6k....thoughts
Red944ls1- Posts : 98
Re: What's Wrong with my Tach?...Help
I think with some of the LS ecus you have to change /re-program the computer to put out the right signal to the dash. Some of them put out the right 4cyl signal and some put out a 8cyl signal.
I had to use a dakota digital signal converter with my car, its an "old" LT1 though
Thanks for the input. I wonder if it would need reprogramming.
UPDATE:
I have fixed my tach. It seems the easy fix was simply correcting the signal in the PCM to the proper signal. It is working fine now
