Which Dipstick Tube & Dipstick To Buy? (Solved)
I am building the 5.3L L33 engine...
The standard dipstick tube for this does not fit the configuration for the 944.
Anyone have the correct part numbers for the dipstick tube and dipstick?
What about brackets, etc, bolts nuts etc, ???
How many quarts of oil am i supposed to put in this thing?
Anyone running an oil cooler, or is the aluminum block OK with dissipating heat into the coolant lines?
Thanks!!!!!
Update: Solved:
Use a 2000 Camaro dipstick tube and dipstick. Then use a small spacer on the block to move the tube away from the header bolts. Then bend the tube slightly to clear the hood. Be careful not to kink the tube!
Update2:
Still have no idea how many quarts of oil i need ro put in it, lol.
Update3:
YES, you need an oil cooler.
Thanks!!!!!
Update: Solved:
Update2:
Update3:
MotoRider42HC- Posts : 116
Re: Which Dipstick Tube & Dipstick To Buy? (Solved)
i got one from GM for a camaro 2000 ? with the ls1 in it. Im running a 6L truck LQ4.MotoRider42HC wrote:I am building the 5.3L L33 engine...
Thanks!!!!!
matt889- Posts : 214
Awesome!
Do you have a part number for it ?
The local dealership isn't exactly cheap, lol, and AutoZone only has universal options.
Did you need any additional brackets or etc?
Do you have a picture of how its mounted to the engine?
Thanks!!!
Edit: Does this look like the correct shape?
rockauto . com/en/catalog/chevrolet,2000,camaro,5.7l+v8,1361450,engine,oil+dipstick+/+tube,5558
Thanks!!!
Motorider...I have not installed mine yet but this is what I found at Summit in 2014 for $58.97. It's supposed to fit all LS motors.
Top half of the unit. Bottom half of the unit.
This is flexible stainless unit that is 13 1/4" long from the top mounting bracket location to the bottom of the bottom fitting.
Hope this helps.
Hope this helps.
Raymond-P- Posts : 380
Haha, i was just looking at Lokar E-brakes, too! Thanks!!! I'll have to send Lokar some love here soon. ^_^
I got the 2000 Camaro 5.7 L dipstick and dipstick tube from gm parts direct. And yes I run a RX-7 FC oil cooler in place of the 944 intercooler. This is crucial for track use, on the street I dunno.
Rich L. wrote:I got the 2000 Camaro 5.7 L dipstick and dipstick tube from gm parts direct. And yes I run a RX-7 FC oil cooler in place of the 944 intercooler. This is crucial for track use, on the street I dunno.
Rich, do you have an iron block or aluminum block?
I'll be running a Rally race called the "100 Acre Wood"... do you think i'll have oil temp issues with my aluminum block 5.3L truck engine?
Thanks!!!
Yeah, aluminum block 5.7 and it took me a few tries to get enough oil cooling. I don't know the event but believe rallying is as hard or harder on a cooling system than road courses.
Rich L. wrote:Yeah, aluminum block 5.7 and it took me a few tries to get enough oil cooling. I don't know the event but believe rallying is as hard or harder on a cooling system than road courses.
well crap... lol, that means my manifold has to come back off and i got to install an oil cooler and find a way to tee-in both my oil pressure sensors...
haha
thanks for the advice!!!
will this fit the TPC oil pan?
amazon . com/Earls-LS0012ERL-Engine-Cooler-Adapter/dp/B01JP2HF5Q
Not positive but I think no.
I have TPC's oil line setup at the pan and the thermostat below. Nice thing is it has 3 spots for gauge sending units.
https://www.holley.com/products/plumbing_an_fittings_and_hose/cooling_systems/oil_thermostat/parts/501ERL
P.S. The link button above the editor next to youtube creates that clickable hot-link...
Here's the diagram of my oil system.
Wow that diagram makes me dizzy, haha, but i bet mine will look just as crazy when it is done.
Thanks for the help!!! I'll have to get pricing from TPC on their oil cooler adapter.
P.S.
Accounts less than 7 days old are not allowed to post links. So i won't be able to post a link anytime soon. Sorry.
P.S.
OK! SO! I bought the 2000 Camaro dipstick tube... but if i close my hood... it will crush the tube...
LOL!
I just want to cry into a box of thin mints...
P.S. LOKAR wants $70 for their dipstick!!! SEVENTY DOLLARS!!! WHAT!?!
https://www.amazon.com/Lokar-ED-5008-Flexible-Engine-Dipstick/dp/B004BSQMD6/ref=sr_1_fkmrnull_2?keywords=Lokar+ED-5008&qid=1552353356&s=gateway&sr=8-2-fkmrnull
LOL!
No no, just give it a little bend forward at the head mounting bolt. No big deal, promise! But wait until you stick coils and plug wires on there too make sure you have lots of room for everything.
I have a brake line bender, would that work? LOL or probably kink it to death!!!
I'm not a mechanic, at all, yet i'm doing my first engine swap with a German car and an American motor...
i'm so screwed
lol
i'm so screwed
lol
Rich L. wrote:No no, just give it a little bend forward at the head mounting bolt. No big deal, promise! But wait until you stick coils and plug wires on there too make sure you have lots of room for everything.
You look like you're doing fine so far! Sounds like Rich L. has your solution. Simple adjustment. Great!
In your pic I see a lift and an engine hoist so I'm wondering if you dropped your LS in from the top. I'm thinking about dropping the cross-member and going in from the bottom...at least that's how I justified my lift. I'm using the TPC long tube headers, and with the limited engine bay clearance, it appears they have to be installed from the bottom anyway.
I need to do some research...what was your experience?
We tried to put it in from the top... no go... not even close... so we had to pull the engine back out, set it under the car on wood blocks, then lower the car and then hoist it up. i was scared to death the blocks would slip and bye-bye oil pan... whew... so harrowing .. i'd link you the video, but it won't be uploaded until sometime tomorrow... youtube.com/powersports
MotoRider42HC wrote:I have a brake line bender, would that work? LOL or probably kink it to death!!!
i'm so screwed
lol
Not sure your brake line bender has a mandrel big enough to fit the dipstick tube...they usually run 3/16" to 1/4" OD. I know bigger pipe benders exist as I inherited a 3/8" OD bender from my father. Perhaps your local auto parts store can hook you up with a loaner tool that's big enough.
In a pinch, I've used a large box end wrench to pin point the bending area and provide the needed leverage. Not the best choice for any kind of serious radius as the tube will begin to flatten and there will be unsightly dents.
Update: Solved:
Update2:
Still have no idea how many quarts of oil i need to put in it, lol.
Update3:
Update2:
Update3:
oil is about 5L +/- .5liters if i remember correct
what is a Liter ? lololol jk jk
so between 5 and 6 quarts...
thanks!!!
thanks!!!
