» Fuel tank over pressurizing
Today at 8:13 am by JW1970
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
What dipstick??
What dipstick??
Post  C4924S on Fri Jun 22, 2018 11:45 am
Has anyone used a C5 dipstick? Does it read levels correctly? Or what dipstick do you guys recommend?
C4924S
C4924S
Re: What dipstick??
Post  chrenan on Fri Jun 22, 2018 2:46 pm
I use an F-Body Camaro tube and dipstick.
chrenan
Re: What dipstick??
Post  murrayg on Sat Jun 23, 2018 9:44 am
you should re-calibrate any dip stick you use. Fill with the correct amount of oil, then check and remark if necessary. Anyone know the capacity of the TPC pans?
murrayg
Re: What dipstick??
Post  chrenan on Sat Jun 23, 2018 4:54 pm
Most LS dipstick tubes mount through the block, not the pan. So if you’re using an LS tube through the block and LS dipstick the marks on the dipstick are accurate as they are relative to the block not the pan. With an F-Body tube and dipstick and a TPC pan around 6 litres in the pan gets me to the top mark on the dipstick.
chrenan
Re: What dipstick??
