Transaxle rebuild
Transaxle rebuild
Hello guys I am looking for info on rebuilding my transaxle. I heard it can be a big task but I cant seem to find much info on it. I have done everything to this point on my swap myself so I was hoping I could tackle this also. I have a grind between first and second that makes it hard to do any harder acceleration. Can someone supply the info needed to do this and where I can get the tools also?
If for some reason I decide to hire it out where is a good place to go for the money?
Josh
Josh
yamamtx- Posts : 97
Re: Transaxle rebuild
Go on Rennlist there is a pictorial thread of someone doing theirs. I sent mine to Kevin Gross
ull need "Special tools "
matt889- Posts : 214
Where can you find those special tools? I haven't seen anyone say where they have gotten them.
yamamtx- Posts : 97
yea "special tools" lol. every vehicle needs special tools to work on, but in most cases i find i can work my way around that. the only "special tool" i found i needed was to hold the main shaft from turning when i removed the 5th gear bolt, but i was able to use a driveshaft coupler and my bench vise to get the job done. past that, the most oddball tool you need is a triple square socket for the 5th gear bolt, and thats not really oddball.
searching on google i was able to find a factory service manual for the transaxle, didnt even take me very long.
I just blew up my NA transaxle. Totally exploded. Wish I’d done the strengthening. Now i gotta decide between vette or turbo trabsaxle. Ugh
Jasonscottw- Posts : 125
I did the turbo trans for a while and it worked well at 400whp. Last winter I built the engine to 515 whp and mounted C5 corvette running gear. That was one heck of a project!!!
yamamtx- Posts : 97
» How much should I pay for an LT1 that needs a rebuild?
» ZF LSD rebuild
» Automatic Transmission rebuild
» ZF LSD rebuild
Today at 4:44 pm by JW1970
Today at 12:39 pm by Nath1142
