ZF LSD rebuild
ZF LSD rebuild
Howdy,
Have any of you guys rebuilt a 951 ZF LSD? I've put that on the list for a winter project this year.
I've done a bunch of searching on Rennlist and Pelican, and understand that the OEM internal parts are available through Porsche & BMW suppliers. What I can't determine:
1) How much of the transmission needs to be torn down to get the LSD out and on the bench, and
2) will the disassembly necessitate special tools or resetting the preload & ring gear backlash.
3) While in there is it possible to add discs or different size discs in order to change the lockup ratios?
There are some good threads on BMW and Rennlist boards, but I haven't found one that's complete from start to finish and specific to the 951 transmission.
http://rennlist.com/forums/944-turbo-and-turbo-s-forum/698051-test-lsd-wear-and-rebuild-parts-how-where.html
Thanks in advance,
Dan.
Thanks in advance,
Dan.
Dan J- Posts : 117
Re: ZF LSD rebuild
When it comes to tranny's I leave that to the experts. I would just send it to Broadfoot Racing if I were you. It costs 100.00 each way to have it Fed EX'ed...
zeusrotty- Posts : 444
Yesterday at 7:12 am by Colibri Green
Tue Mar 26, 2024 7:28 pm by Raymond-P
Tue Mar 26, 2024 4:29 pm by Blaizefed
Tue Mar 26, 2024 2:30 pm by Raymond-P
Tue Mar 26, 2024 9:49 am by 948
Thu Mar 21, 2024 12:52 am by Raymond-P
Wed Mar 20, 2024 2:17 pm by Rob44
Tue Mar 12, 2024 4:22 pm by dcoutofstep
Tue Mar 12, 2024 3:10 pm by dcoutofstep
Tue Mar 12, 2024 1:12 pm by ndog52
