wiring harness connected to 944 harness?
Hello Guys,
I only have Brakes left to do and a few odds and ends before my swap runs. I have my LS wiring harness done but I don't see much info on where I need to hook it into my 944 harness. Any info on this portion would be awesome! Thanks for the help.
yamamtx- Posts : 97
Re: wiring harness connected to 944 harness?
These should get you started.
https://944hybrids.forumotion.com/t1450-which-relays
https://944hybrids.forumotion.com/t1310-could-someone-check-my-plans-for-wiring-the-fuse-block
https://s94.photobucket.com/user/xschop/media/948Fuseblockandrelays-1.png.html
Hope it helps.
Hope it helps.
yamamtx wrote:I don't see much info on where I need to hook it into my 944 harness.
We have a dedicated sub forum just for electrical!
https://944hybrids.forumotion.com/f5-electrical-mods
I had looked through a lot of the electrical area but didn't see much for info on the wires I would be looking for on the 944 side. I posted in this section because it seems like this area actually gets responses. I'll keep looking and I appreciate the info already posted. Thanks
yamamtx- Posts : 97
I was also was curious on how people cleaned up the wires they didn't need in the engine bay on the 944 side?
yamamtx- Posts : 97
Does anyone have any info on how they are hooking up there LS harness to an early 944 9 pin? Info and pictures needed please! Thanks
yamamtx- Posts : 97
Search function produced this....
https://944hybrids.forumotion.com/t957-9-pin-firewall-connector-early-cars?highlight=14+pin+connector
I actually did see this write up and it was the only one that seemed to apply to what I was looking for. Out of this entire project my weakest area is wiring so I just can't wrap my head around it quickly. I was hoping someone had a little write up like lt1swap has for the harness. Very good directions with good pictures. If I can't find something like that I guess I will give it my best shot. Thanks and keep the info coming if more people out there have it.
yamamtx- Posts : 97
Today at 12:47 am by sharkey
