Wiring Harness
Wiring Harness
More credit where due.
Just got another parcel today, my wiring harness and fuse block along with re-programmed ECU from SSP Wiring. The job is excellent, I chose the de-luxe show covering and it looks great.
They assured me that all modified harnesses get run on a test engine.
The Installation Instructions are excellent and are a mine of information about the various sensors.
I had a Vette wired throttle body, SSP traded me a cable type in the deal.
Re: Wiring Harness
What fuse block did you get?
Did you know that they use the same VIN for all of thier reprogramming? Dont know if this matters to anyone else. It does to me. Need to have traceability back to teh original car. MY T/A computer is now a camaro with a different VIN.
VIN #
No I did not know that. Does it matter? What does the VIN number really do as far as the electronics are concerned? They have reprogrammed my ECU and also made a small performance increase.
Re: Wiring Harness
It only matters if you are in a state that requires that you have information that links the engine to the actual vehicle it came from. I am in California and I was told by the BAR that I will need this.
Re: Wiring Harness
I was wondering if your harness has one of the wires labled "performance". Do you know what this wire is for?
Last edited by Bluemach1 on Sun Nov 07, 2010 7:35 pm; edited 1 time in total (Reason for editing : typo)
Wires
Ted,
Yes I have a Dark gray wire marked "Performance", have emailed ssp for clarification.
News
Not yet, will call them tommorrow, perhaps they don't check emails everyday.
Performance wire.
Ted,
I talked to Steve at SSP Wiring today, here is some info:
1. The Blue wire "Performance" is really intended for auto transmissions.
It can also be used for manual cars, it forces the computer into a more agressive
Timing and Fuel Map. You have to connect this wire to +12 volts.
2.The "Check Engine Light" wire puts out a ground, the bulb has to be connected to a
+12 volt source on the other side.
3. If you have the OBDII port, Green goes to OBDII wire in the harness
Orange goes to +12 volts (Battery Hot)
Black goes to ground.
Hope this helps,
Mike
Hope this helps,
Mike
Today at 12:47 am by sharkey
