Ford Hydroboost to Porsche 951 Master Cylinder Adapter
+16
simon123
RS Technic
GarethW
zeusrotty
cjbcpa
Vorsche944
phlip
Porschedoc
20 posters
Page 4 of 5
Page 4 of 5 • 1, 2, 3, 4, 5
Hydroboost adapter still available?
Are these Adapters still available? I will buy one if they are available. Also what are the part numbers that I need to buy to get all the parts for the ford Hydroboost? Thx
BeaverDeceiver- Posts : 10
Re: Ford Hydroboost to Porsche 951 Master Cylinder Adapter
Call Kent at TPC, I know he has adapters in stock.
phlip- Posts : 67
In this pic at the very left of it you have some kind of spacer in the line? What is that for? Also what kind of o- ring should I be using with the adapter? Just anything from the parts store?
[/quote]
[/quote]
zeusrotty- Posts : 444
That is a brake line coupling; the original brake line is not long enough so an extra section is required. You can purchase these from most autoparts stores; the line is about 6 inches. No o-rings, it is a flared tube just like the factory.
[/quote]zeusrotty wrote:In this pic at the very left of if you have some kind of spacer in the line? What is that for? Also what kind of o- ring should I be using with the adapter? Just anything from the parts store?
Okay I have a few questions. What size bolts are used to mount the Porsche master to the already threaded adapter? Also, do I need any other bolts? Like from the HB to the adapter?
Secondly, I am running the Wilwood 6R's... And then the Wilwood superlites in the back. Will I be able to get get rid of the proportioning valve? Or do I need to keep that?
The threaded holes in the adapter to mount master are 8mmx1.25.
I used 10mmx1.5 allen bolts with a thick washer and lock nut to mount adapter to booster.
Dont remember the legnth of either set of fanteners, but that should be easy to figure out.
phlip- Posts : 67
Call Wilwood, they will run the numbers for you.
So many have everything installed and I'm wondering if you guys are seen a difference in pedal height at all? Do your brakes feel different?
Mine is installed but I haven't had a chance to drive the car yet as more work is still getting completed. Hopefully I get the car back in the next few weeks and I'll report my findings...
Okay, so now I have brakes! But the pedal won't come back up all the way. Any suggestions?
Sounds like you still have air in the system. Bleed the brakes again, if it's still like that you may need to bench bleed the master cylinder, then rebleed the brakes...
Hmmmm. When I bled them just now I did not Depress the brake pedal. I just used the power bleeder. I should probably try to pump the brakes and see if I can get more air out. I'm seriously getting sick of this car. It's always one step forward 2 steps back.
Old fashioned two man bleed always works better when you know there's air in the system. I've found the power bleeder works well if you only have to do a typical flush. It doesn't seem to put enough force on the fluid to really push out large amounts of air that you have when you swap MC/calipers/lines etc.
It seems as though I had the bolt on the brake arm to tight. Haven't driven it or anything because it's raining out but it actuates and feels way better. I can press the brake to the floor let up and move the car back in forth.
On to the overheat issue...
To reference the bolt question above. All units going out now will come with all the Bolts, Lock Washers and Nuts for installation.
If anyone needs one, we have plenty in stock.
www.944Transformations.com
Just so everyone knows I have mine up and running at it is way better than the ford master. Love it. Pedal feel is better. Feels like a normal brake. It doesn't come to a screeching halt with just a minor touch anymore.
zeusrotty wrote:Just so everyone knows I have mine up and running at it is way better than the ford master. Love it. Pedal feel is better. Feels like a normal brake. It doesn't come to a screeching halt with just a minor touch anymore.
Lol, I hit my head on the rollbar first time i hit the brakes in the parking lot with it installed with GT3 brakes on the car. Wasn't quite ready for that after being use to the effort required with manual brakes.
Can someone with the adapter installed etc post a pic looking from the front to back, to show clearance between HB and the valve cover.
kevin924kevin- Posts : 927
Remind me and I'll take one tonight...
Doc, thank you, very much appreciated.
How're these? Click on the one showing the entire engine, it somehow got cropped in the post but does show the MC...
Doc, thank you for the pictures.
Doc, what push rod did you use between the MC and the HB. In the brake clevis post I did, Spence attached some really nice drawings.Is that push rod the one.
Is that what you used as you have the adapter installed for the factory MC. Thank you.
» Ford Hydroboost fittings issue
» Where can I find mounting plate for Ford hydroboost?
» Clearance for Tilton master cylinder when using Hydroboost
Page 4 of 5
Yesterday at 8:32 am by Rob44
Yesterday at 8:28 am by Rob44
