Hydroboost Master Cylinder Options
Trying to determine good options for future master cylinder upgrades.
Running Kent's Hydroboost setup with the stock master currently.
Has anyone upgraded master cylinders? running wilwoods front and rear and thinking they may benefit from a larger mc to reduce pressures.
rjarvis- Posts : 61
Re: Hydroboost Master Cylinder Options
I've always used the stock master and felt it was more than enough. Only other master cylinders i've used were were a Tilton pedal box. It didn't have any assist and honestly felt they were not that great.
I've used the hydroboost and stock master with big reds on a 944 and wound up taking the big reds off and using stock turbo calipers. The brakes were way too aggressive and touchy with the reds.
Hotrodz of Dallas wrote:I've always used the stock master and felt it was more than enough. Only other master cylinders i've used were were a Tilton pedal box. It didn't have any assist and honestly felt they were not that great.
Thanks Dallas . Ill give it a shot with the stock master...should be actually getting it on the road in the next few weeks.
rjarvis- Posts : 61
Awesome. You'll have fun. It's the way Porsche should have built them.
» Clearance for Tilton master cylinder when using Hydroboost
» Ford Hydroboost to Porsche 951 Master Cylinder Adapter
» Master Cyl Relocation
Yesterday at 8:32 am by Rob44
Yesterday at 8:28 am by Rob44
