Clearance for Tilton master cylinder when using Hydroboost
I ordered a larger Tilton master cylinder kit from TPC to replace the stock one and it looks like it will not clear the aluminum piece attached to the hydroboost by a bonjo bolt where the hoses are attached. Even if it will clear the hydroboost, it looks like the line to the slave cylinder is going to hit the strut tower. What is your experience in attempting to install the Tilton master cylinder with the hydroboost already installed? Everything in that corner of the engine compartment is a pain to work on and I'm trying to decide if I should mess with it or leave it alone. Thanks, Gil
gwistrup- Posts : 113
Re: Clearance for Tilton master cylinder when using Hydroboost
I've used several of these. They will clear the hydroboost, but just barely. And as far as the line hitting the strut tower, as long as you use a 90 degree fitting in the M/C, it will clear.
Yes that corner is very tight.
I will give it a shot and attempt to install the larger master cylinder. It would be nice to have the clutch release a little farther from the floor. The goal for this summer is to address all the loose ends and the clutch is one of them.
» Sold -Tilton Master Cylinder
» Hydroboost Master Cylinder Options
» Ford Hydroboost to Porsche 951 Master Cylinder Adapter
Today at 8:32 am by Rob44
Today at 8:28 am by Rob44
