Early SBC Coversion - Spacer Plate
Good Day Everyone
I am doing an early SBC conversion and understand I need a spacer plate between the block and bellhousing. Do you all know where I can find this part? I am curious to see a picture? Does is also serve as a block protector in the event of a flywheel failure?
Ed
Ed
mred2nice- Posts : 79
Re: Early SBC Coversion - Spacer Plate
I've happen to have one of these I didn't use if you'd like to purchase it from me.
The only way you'd know you need one is if you measure your clearance from your throw out bearing to the pressure plate fingers (https://www.mcleodracing.com/content/tech-article/determine-dimension-using-mcleod-hydraulic-bearing/). All it is a 1/8" shim and yes it would help protect if your clutch or flywheel exploded.
Thanks for replying. Can I call you tonight about it?
