1987 944 turbo look LS3 swap
recently got this running and driving 1987 944 na. the cars intended use will be a road race car that will still have lights and a tag in the event i take it to a show or parade. i have a turbo front bumper and turbo rear lower valance because i like the look. also have boxster s brembos i build a adapter for so they fit the 944 platform. i am building my polygraphite mounts from blocks on my lathe as there does not seem to be much support for the 944 in the bushing category besides high end expensive tarrett or elephant racing stuff. building my own adjustable coilovers. going to install a scca roll cage for road racing. i did not purchase a LS kit as i understand they are in mid limbo right now in re engineering it. so i am building my own. my background, im a retired porsche master tech, and machinist. i am not new to the conversion game, as i have done several 911 LS swaps. this car has no rust and is a good candidate for the swap. i have a ls3 that im building for the swap. asa cam, ported heads, ported intake, ported throttle body, ported maf, long tube 2" headers, etc etc. similar one i built earlier in the year made 590hp at the crank on pump gas. first pic is when i picked it up. second pic is after i got it home and installed the 993 18" turbo twists on it. here we go... [You must be registered and logged in to see this image.]
964ruf- Posts : 22
adapter machining
here i start machining the adapter for the c6 manual bellhousing to 944 torque tube.
964ruf- Posts : 22
c6 to 944 adapter
getting ready to bore pilot hole. pilot bearings just laying in the pic.
964ruf- Posts : 22
tearing down the LS3
964ruf- Posts : 22
parts
parts are starting to come in... engine plates, so i can fab up engine mounts. c6 tb. arp flywheel bolts. arp clutch/pressure plate bolts. ls3 gmpp valve springs for asa cam. timing set for engine. ls9 head gaskets. german lower balljoints. c6 oreillys heavy duty pressure plate 20% more clamp load. hayes kevlar clutch disc. more to come...
964ruf- Posts : 22
hydroboost
964ruf- Posts : 22
Re: 1987 944 turbo look LS3 swap
Keep up the good work! looking forward to more pics and info on your car
Saittek89- Posts : 6
more parts
more parts are showing up daily.... wink mirror, only944 short shifter, only944 shift linkage, torrington bearing and bolt fix for shifter handle, new shift bushing, type 2 cv's, 968 M030 front and rear sway bars, bilstein adjustable coilovers, etc etc.
964ruf- Posts : 22
Adjustable Bilstein B6 87-89 front struts
building my 87 late adjustable bilstein b6 front struts with paragon setup, 400lb hypercoils, with overload/helpers, and mk1 monoball adjustable camber plates. before install i will paint the housings bilstein yellow and apply bilstein decals.
964ruf- Posts : 22
87-89 bilstein b6
964ruf- Posts : 22
ls3 mild build
the ls3 will be a mild build. stock ls3 intake and throttle body and ls3 injectors. other than that, the heads are shaved .030 and ported. gmpp ls3 blue springs, and gmpp asa race cam. 1 7/8" longtube stainless headers, cai, and a good tune should make a respectable 550hp at the crank easily. will make a monster at the track or any other event.
964ruf- Posts : 22
Looks like you are well on your way. Look forward to following and learning.
What part of the country are you from?
Ryan
Ryan
ryan08- Posts : 15
Interesting Project
964ruf
Just started following your build...it's looking very interesting so far.
With your background, a machine shop and ingenuity, you are adding a new dimension to the term "DIY."
Looking forward to your future posts!
Raymond-P- Posts : 385
» FOR SALE/TRADE 1987 944 TURBO (& 1983 944 PARTS CAR) 350 SBC SWAP PROJECT - $5.5K OBO OR TRADE
» FS: 1987 Porsche 944 Turbo
